Turbo strip down....
As above folks. I've striped down my 2wd turbo for a few resons. two main ones being a leak on the exhaust side. kinda like a drip of oil coming out where both flanges bolt up. Other being play ..... not up-down play but in/out. on inspection this play is a worn bearing and the mushroom part for want of a better way to explain it. where can i get these parts and all seals to go with them. its a sdt t3 part
Unless you have a rebalancing machine, you would be advised to send to someone who has.
I use the TURBOCENTRE, 01924 404112, speak to Andy or Craig, they can supply any parts you need or mods etc etc.
JK12
33
Apr 26, 2021 12:09 PM
Matt Baxter
Sep 16, 2015 08:30 PM
