Cosworth clutch...??
Old Feb 4, 2008 | 04:25 PM
2wd's Avatar
2wd
Default Cosworth clutch...??
Hi...just want to ask what sort of clutch you are running on your Cossies...?
I currently run a AP 6 paddle with std cover and bearing....its as light as a std witch is fine, but I dont like the feel as its difficult when starting from standstil...there is a lot of "judder" at first...but when going it seems fine....SO I have decided to try and find a better one...hopefully
Car is a 2wd Sapp. Cosworth running siemens 55', T-34, MSD chip and so on....
please advice.....
Old Feb 4, 2008 | 04:52 PM
mechanic28's Avatar
mechanic28
i am running a alcon 6 paddle with a heavy duty cover with roughly the same spec seems ok to me slight judder but not that bad!did u have to flywheel skimmed?
Old Feb 4, 2008 | 05:15 PM
Alvyn's Avatar
Alvyn
IF it's juddering with that set up then there IS other issues going on, I know plenty of Cossie's running that and ALL are fine!
as said was the fly wheel re-faced as this could be the problem!
Old Feb 4, 2008 | 07:23 PM
2wd's Avatar
2wd
Hi...no it was not refaced,...as it was brand new from a Ford Dealer so I did not think that I needed it .....???
Any chance that the company who put the engine/clutch together, could have done it wrong ?
what else could be a problem..?
Old Feb 4, 2008 | 10:43 PM
coachworz's Avatar
coachworz
i am having the same problem here...
Old Feb 5, 2008 | 06:38 PM
Alvyn's Avatar
Alvyn
if it was a brand new fly wheel there shouldn't be a problem there, did they check/change the spiggot bearing??
I've known of a couple of 2 w/d's that the 4x bolts that hold the bell hsing to the box to be lose and that has caused a slight judder/vibration!
regarding the garage fitting it wrong cant see it tbh!
try another cable 1st as that's the cheapest option!
Old Feb 5, 2008 | 06:51 PM
rapidcossie's Avatar
rapidcossie
I have the same set up and its fine.
ALL paddle clutches will judder due to the paddles and the way they grip the flywheel.
You can really slip a paddle clutch so its something that you need to get used to.
Old Feb 5, 2008 | 07:15 PM
2wd's Avatar
2wd
Hmmm....so if I dont want get used to it ...I'll need a organic clutch right..??
So anyone want to recommend a god organic clutch kit to use ??
Old Feb 5, 2008 | 07:17 PM
SillyFezzaMk1's Avatar
SillyFezzaMk1
Rubber Rhino Crew
mine on ebay........finishing soon, I'll end early for a good offer!
http://cgi.ebay.co.uk/ws/eBayISAPI.d...MESE:IT&ih=013
Dan
Old Feb 5, 2008 | 07:20 PM
SillyFezzaMk1
Rubber Rhino Crew
I am also looking for a 6-paddle clutchplate and std cover myself.....so could do a p/x if your clutchplate is still in good condition.
Dan
Old Feb 5, 2008 | 07:23 PM
2wd's Avatar
2wd
Dan
sounds interesting...I'll put a pic of it here in a sec.
Old Feb 5, 2008 | 07:25 PM
SillyFezzaMk1
Rubber Rhino Crew
cheers
Old Feb 5, 2008 | 07:31 PM
2wd's Avatar
2wd
Hi..here is some pic's.......I dont know much about clutches....but it looks ok to me ... I do not have pics of the cover, but can get some if you want ??
please let me know if interested...otherwise please pm me how much you will sell it for
Old Feb 5, 2008 | 07:34 PM
SillyFezzaMk1
Rubber Rhino Crew
how many miles ahve you done on the clutch?
dan
Old Feb 5, 2008 | 07:44 PM
2wd's Avatar
2wd
well a bit more than yours...I think around 7-8000km....approx 5000 of them was running in my new engine....the rest has been to and from job and 4 shows...??
Old Feb 5, 2008 | 07:45 PM
SillyFezzaMk1
Rubber Rhino Crew
pm sent
Old Feb 6, 2008 | 09:06 AM
2wd's Avatar
2wd
pm sent
PM back...
Billy_RS
Sep 13, 2015 04:17 PM
28
Sep 8, 2015 07:10 PM
Adam Graham
Sep 6, 2015 06:04 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
