rst timing
Old Feb 3, 2008 | 11:43 PM
mk1trb's Avatar
mk1trb
Boost Junkie
Default rst timing
hi guys, i'm having problems with my turbo cabrio, its running s2 erst engine and management, chipped, alloy cooler, flowed head. its running 16psi but when you floor it it will pink initially but go after a few seconds but wil pink for a little longer in 5th, but if i turn the dizzy all the way towards the front of the bay it dont pink at all but has massive lag, its driving me mental as im worried the engine is gonna pop, its running slightly rich wud this cause it?, i have changed the metering unit, plugs, leads, cap, arm, anything else i can check?
cheers in advance
Old Feb 4, 2008 | 10:57 AM
antony215's Avatar
antony215
Escort Rs Turbo
Id take it and get it setup by a PRO to much fuel can be just as bad as to little.
Old Feb 4, 2008 | 05:58 PM
project rs's Avatar
project rs
as above get it too some one that knows what's what
Old Feb 4, 2008 | 06:08 PM
mk1trb's Avatar
mk1trb
Boost Junkie
right o, t&m's it is then
cheers guys
JK12
33
Apr 26, 2021 12:09 PM
Adam Graham
Sep 6, 2015 06:04 AM
Shows & Track Days
Sep 4, 2015 07:16 AM
hopper350
Sep 4, 2015 12:53 AM
