fiesta si with 2.0l 16v engine piper or kent cams?? help!!!
hi i got a fiesta si mk3 withe 2.0l mondeo engine fitted and wondering which cams should i fit kent cams or piper cams??? and will i need to chip it or remap it to make it run ok or will the standed 2.0l injeters work fine?? HELP PLEASE!!!!!!
The standard 2.0 ltr cams are good for 170 bhp. Your inlet manifold can only flow enough air for approx 150 bhp. You do not need new cams!!!!!
Your next step is aftermarket management. Then you need to look at a better inlet and only then shoudl you consider new cams.
i only got the 1.6 zetec manifold on at the mo but 2.0l thouttle body on it with 2.0l injeters runs fine but wot manif old should i fit on it to make it faster or should i port and polish the 1.6 bigger??? help please
JoeyBoyden
Jan 4, 2024 02:36 PM
