spark problem on my saff!
hello people got bit of a strange problem on my saff ive not long put the head back on after a valve problem and whilst i was there i put 55lb injectors and a msd chip new cap and rotor ect.....
the problem ive got is that i'm getting a continuous spark to number 1 but 2,3 and 4 only spark the once when keying over
each plug sparks once when the ignition is switched on and off also, is that normal?
cheers, dean
cheers, dean
same probs i had on mine i had plugged the knock sensor and Crank Position sensor in the wrong way round
try that it fixed mine also is your fuel pump priming when ignition is switched on?
and if so it should switch off after about 5-6 secs, if the CPS & knock are plugged in wrong way round it stays on constantly
just been and tried that mate and it didn't make any difference, ive only got a plug for the cps sensor and a plug for the phase sensor mines a 2wd btw
got a black plug on the phase sensor and a white one on the cps
it's proberly some thing really stupid but i'm running out of ideas now
anyone else have any ideas to what the problem is?
but what i don't understand is that plug no1 is getting a constant spark as it should do and 2,3,4 arn't they only spark once when keying over and when turning ignition on and off
i thought that the ecu would have no control over when a cylinder gets it's spark and so on as thats the cap and rotors job
DixieTheKid
11
Jun 6, 2020 11:20 AM
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
DixieTheKid
Sep 14, 2015 09:04 PM
