CamShaft Change??help
Old Feb 3, 2008 | 09:40 AM
seanex's Avatar
seanex
Default CamShaft Change??help
Right, after the offers Ive had for my car with a worn cam I have decided to fix it. Need some help though.
1. Do I need to set the engine to a safe position before I remove the cam?
2. Will the cam shaft only fit into 1 postion on the pulley?
3. I really need your help and your experiences of doing this cause I dont want to fook it up.
CheeRS
Old Feb 3, 2008 | 09:44 AM
zetecapri's Avatar
zetecapri
2.0 16v Turbo
yes and yes, time the engine up like you would to do the belt to remove the cam, and there is a keyway on the cam where the pulley goes on so you cant get the timing wrong once its in.
Old Feb 3, 2008 | 09:52 AM
seanex's Avatar
seanex
cheers for that, sorry to be thick but ive only timed up an engine thats on a stand....not in a bay. Whats the best way of doing that because obviously access to turn the crank is limited compared to what I have worked on
Nov 1, 2015 06:53 PM
dojj
Sep 29, 2015 10:32 PM
rsguy
44
Sep 29, 2015 03:29 PM
marky_g
Sep 12, 2015 04:26 PM
