help with top mounts
Old Feb 1, 2008 | 12:33 PM
acosted's Avatar
acosted
Default help with top mounts
help needed please , the time as come for me to try and get me escort cossie track car back together but am havin couple off problems with the strut top mounts av bought some pro flex coilovers that have canisters on but ant sure as to where or how to mount the canisters and also what top mounts to buy to use with them
there aint a proplem cutting the strut top on the car if need be
a couple off pics off the coilovers am talking about
has eny one got eny pic off the same coilovers on ther car or help in finding some whereto buy the write top mounts thanx ted
Old Feb 1, 2008 | 04:37 PM
jon@work's Avatar
jon@work
what style do you want (rubber mounts, spherical bearings, concentric, eccentric, adjustable, fixed, etc), what's the car going to be used for, and what's your budget ?
Old Feb 1, 2008 | 05:11 PM
Obviously this is a serious track car as opposed to everyday car/track car.
I would get adjustable top mounts for castor camber, these normally have a centre bearing so that the strut fits into it, may have to use a few spacers etc but anyone that supplies these should be able to advise.
Old Feb 2, 2008 | 11:06 AM
rsturbowhite's Avatar
rsturbowhite
jon@work
the car that this is geting fitted to is a full on track car if u look in parts wanted u can see the car
write a no abit about the plans with the car as teds told me the plans , he is looking to use spherical type bearing , so that he can ajust the camber and caster
Old Feb 2, 2008 | 08:26 PM
NUTS RuS's Avatar
NUTS RuS
12 or 14mm top insert ?
Old Feb 3, 2008 | 04:18 AM
rsturbowhite
nuts
there are 14mm inserts
Old Feb 3, 2008 | 08:18 AM
NUTS RuS's Avatar
NUTS RuS
We have plain doughnut type with 20mm bearings and 14mm sleeved inserts with a M14x1.5mm nut available or eccentric 110mm ones with the same hardware, or plain ones with the same.
Do you have adjustable bottom end ?
We have adjustable track control arms for camber and adjustable compression strut kits for castor.
If you move the wheel about at the bottom then sometimes a plain top mount will suffice.
Tony
Old Feb 3, 2008 | 03:20 PM
rsturbowhite
[b]tony
teb has fully adjustadle track contoll arms for the car alltho wen i looked at them am sure that one is bent , so am allmost sure he will need a new set for the car , but want be speaken to him till monday ! will come back to u with that ?
also think with the top mounts , we are blind to wot we need as its the first car that me or ted has put coilovers on , so eny help would be greatfull ie the best mount to use for the best rezults
thanks
graham
Old Feb 4, 2008 | 08:24 PM
MEF's Avatar
MEF
Former Sponsor
I can't see a problem with the top mounts that Tony mentions, just have to fit the cannister under the wheel arch with that type of Proflex.
martin
yatta
May 21, 2016 10:31 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
StephTell
Sep 2, 2015 06:31 PM
