Oil in 2wd cossie spark plug ports
Car started missfiring etc so had a check round to see what was up. Pulled leads out and checked in port where plugs were and they were all half covering the plugs with oil.
They were drowned kinda thing with oil all around them.
whats happened?
any ideas?
cheers
whats happened?
any ideas?
cheers
the rocker cover gasket would make the plugs be drowned in oil, the oil was like covering half of the plugs
nothing else or any other seals that could of failed?
Originally Posted by tabetha
No just the rocker one as said.
Fit a COMETIC reuseable one, with Loctite 5900/5910 on the half moons never leak again.
DON'T overtighten the bolts and it will be fine.
Thanks mates!
Alvyn
but what is the difference between gasket for early 4x4's and last 4x4?
Originally Posted by Alvyn
cometic gasket number is SC779COM @ about Ł35 and this one ONLY fits 2w/d's and ALL early 4x4's!
[quote="Yura"]Thanks mates!
Alvyn
ok the gasket mentioned WONT fit a small turbo Escos which is also a 4x4
and regarding your pm sorry I dont have one
Zoggon
Aug 10, 2015 10:39 AM
