Can someone tell me the difference between a normal Sierra 4*4
turbocharger (T3.48) and a T34.48?
Is it just the compressor wheel and the compressor housing, or also
some differences at the exhaust side?
As you say comp housing/wheel is different and the exhaust housing is MOVED around in realtion to 2wd, so actuator sits in a different postion, but easy to have either way.
So just the bigger compressor wheel, increases the power for about
50-70bhp with nearly the same lag as an original T3 turbo?
You get more lag with the bigger compressor wheel, as it takes more exhaust gas before the turbine wheel has enough force to spin the larger compressor wheel up to a similar speed.
