Are 2wd & 4wd diffs the same
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
Originally Posted by AndyPen
They are different mate - think its 7.5 inch for a 2wd and 7 for a 4wd. Am sure someone will confirm if I'm right
aka Turbosailorboy
Originally Posted by kjc300
Won't a 4x4 one fit with a couple of spacers?? Thought I heard that somewhere?? Are the driveshaft mountings the same?
I hope thats confused you somewhat Kev
the 2wd diff is wider at the top than the 4wd diff which is why it won't actually fit into the beam, but it's not structural, only for the bolt to go through so you asn remove it without any problems
the other major differences are that the 2wd diff has 108mm output flanges and the 4wd one has 100mm output flanges
and you can't just get away with changing the shafts for 4wd ones either because the other ends where they gfo into the stub axles/hubs etc are also bigger so these would need to be changed as well
a bit of an arse reallty
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
dojj
28
Sep 11, 2015 10:00 PM
