Markings on Cams for Cosworth
Hi,
I don't know if this is any help, but my cams for my 2wd sapphy are marked,
Inlet = LYD4 YN0011, they are 446mm in length, and have a groove around each bearing journal.
Exhaust = LYD2 YN0011 446mm length.
Originally Posted by stage 3 muppet
will have a look at mine tommorrow pal and tel ya what they are seen as its now in bits
and after me putting new tappets in aswell
ah well
ah well
it all depends you can have standard cams reground to what you want. i have bd14/bd15 reground from standard cams which are kent cams and they have the relevant numbers stamped on the non pully end of the camshaft( KCBD14/KCBD15 )
jessie_rs
11
Jun 3, 2019 04:57 PM
Danielbetty
Oct 3, 2015 06:01 PM
Aug 14, 2015 07:29 AM
