Low Idle Speed After Hard Drive.......
Does anyone else have the same problem? After a spirited drive, the idle speed becomes erratic and low, sometimes stalls too!
If you tap the Idle Speed Control Valve it run back up to normal idle speed..... I've tried changing the ISCV 3 times now, and it still seems to have the same problem!!!
Thoughts anyone?
Thoughts anyone?
TPM961
Jan 15, 2018 10:50 AM
