gearbox vibate/ rough
Old Jan 25, 2008 | 12:53 PM
coachworz's Avatar
coachworz
Default gearbox vibate/ rough
hi,
i notice my T5 gearbox is very noisy and rough... esp when i lift off my accelarator to coast.. it is very noisy.. any idea why? i got new group N gearbox mount/ new stock engine mount and rear diff mount.. yet the noise and vibration continues....
Old Jan 25, 2008 | 01:27 PM
LHD220Turbo's Avatar
LHD220Turbo
what car?
Old Jan 25, 2008 | 01:28 PM
LHD220Turbo
what spec is the engine - your asking questions which depend on alot of thing!!!
Old Jan 25, 2008 | 01:29 PM
LHD220Turbo
is the T5 brand new? old? reconditioned? how many miles has it done?
Old Jan 25, 2008 | 01:58 PM
coachworz's Avatar
coachworz
its 2wd sapp 88 model.. stock engine . history unknown as i just got the car.
Old Jan 25, 2008 | 01:59 PM
coachworz's Avatar
coachworz
its not recon.. think its the orignal condition.
Old Jan 25, 2008 | 02:02 PM
LHD220Turbo
probably needs a rebuild then -
Old Jan 25, 2008 | 02:41 PM
coachworz's Avatar
coachworz
where can i buy rebuild kit? since i am rebuilding it.. any stronger kit i can get hold of without too high a cost?
Old Jan 25, 2008 | 03:34 PM
LHD220Turbo
search ebay.co.uk; loads on there; also buy the cd through ebay which tells ou about rebuilding
Old Jan 27, 2008 | 09:05 AM
crystal cossie's Avatar
crystal cossie
I had the same vibration on my 2wd i also used the group n gearbox mount, I replaced it with a new standard item and all was fine. The group n is so solid and has hardly any flex compaired to the standard one.
Old Jan 27, 2008 | 09:47 AM
coachworz's Avatar
coachworz
so its due to the mount..
Old Jan 27, 2008 | 01:20 PM
155lee's Avatar
155lee
my car has just developed the same problem,only since i fitted a quickshift,mine is a 1990 2wd which is pretty standard,it vibrates and grinds,the only thing i think it could be is that the propshaft isnt lined up correctly.im going to get it in the air and check it this week!
Old Jan 27, 2008 | 02:03 PM
coachworz's Avatar
coachworz
didn't know prop shaft needs to be align...
Old Jan 27, 2008 | 08:32 PM
155lee's Avatar
155lee
had to undo the propshaft bearing carrier to let the box drop enough to get access to the shifter,its the only thing i have done that could be causing the noise(hope so anyway)!
chowfornow
14
Jan 5, 2019 09:01 PM
mjonathan24
Oct 29, 2015 10:39 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Iain Mac
Sep 30, 2015 09:39 PM
