Front Hubs
Should I be able to remove the front hub from the carrier??
When I was taking the Mo's off the car, The rim had become stuck to the hub (obviously not enough copper grease!!) and when pulling the front hub started to move free of the carrier.
Is this the norm? Or are my hubs fucked!
if you yhaven't pu the hub nut on they will move fairly easily
but they won't come out
they just fuck up the bearings as they split when you pull them and then you can't get them seated properly again
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 3, 2015 04:08 PM
but could be the hub or carrier
