Injector cleaners
Old Jan 24, 2008 | 07:27 PM
godzilla's Avatar
godzilla
Default Injector cleaners
Always wondered in the 17 years of driving if these petrol additives like injetor cleaners really work.....if they do is there a particular one which is better than the rest?
Old Jan 24, 2008 | 07:58 PM
mechanic28's Avatar
mechanic28
we use a treatment called forte at work,it is very very good stuff will get a car through emission alot of the time plus can sort out some running issues
Old Jan 24, 2008 | 09:38 PM
godzilla's Avatar
godzilla
Never heard of that one mate, where do you get it from? Ive heard of STP injector cleaner, Nitrox hot stuff, Redex petrol cleaner.
Could some of these help with running probs or clean the injectors?
Old Jan 24, 2008 | 09:40 PM
zetecapri's Avatar
zetecapri
2.0 16v Turbo
We use fortron where we work, and it helps sometimes if a car has failed on emmisions, manages to get through after one of these and a little thrashing We do use engine flush and other additives too though.
Old Jan 24, 2008 | 10:05 PM
mechanic28's Avatar
mechanic28
yer it can help and will help the injectors we get it direct from forte if u aint far from me i have got some u can have(petrol car i take it?)
Old Jan 25, 2008 | 08:27 AM
Some are better than others, FORTE is good as is MILLERS.
A lot depends on why the injectors are sluggish, these additives will NOT get rid of varnish and gum deposits from where a car may not have been used for months on end.
None of the additives even come close to ULTRASONIC cleaning though, but aren't ultrasonic money either, which is normally around £50/60 a set to clean, but you will know the CC/min rate of each one after as well.
mk3ste
Oct 17, 2021 10:09 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
