Watching movies from PC on TV......
Old Jan 23, 2008 | 07:19 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Default Watching movies from PC on TV......
I would like to connect my PC to the TV. The PC has lots of connectivity on the front, such as S-Video and Composite etc.
We have an Amp for the TV sound, so what would have to be connected to what?
Do I need an S-Video to S-Video lead from the PC to the TV for the picture and Composite to Composite to the Amp for the sound?
Old Jan 23, 2008 | 07:24 PM
St3V3_C's Avatar
St3V3_C
Neither of those carry sound, and s-vid will be the better picture.
For the sound you need a lead to plug in to the PC where you would normally put speakers, or the line out if you have it, and 2 phono's on the other end to connect to the amp.
HTH
Old Jan 23, 2008 | 07:28 PM
Christian and Beccy
#1 in Spelling Club
OK, I have several connectors on the front, but just normal headphone style jack plugs.
However, I have just spotted a 'Digital Audio In & Out' connection point on the rear of the tower. Those any good? Each is a single Phono style plug.
Old Jan 23, 2008 | 07:30 PM
St3V3_C's Avatar
St3V3_C
If you have digital audio in on the amp, then that will be the best way to connect as it will do surround as well.
Fil's Avatar
Fil
ELASTIC BAND
digital co-ax, is how my pc is connect to the amp
and
svhs to my tv
Old Jan 23, 2008 | 07:33 PM
tonyk's Avatar
tonyk
As said above regarding digital connections. If your amp does not have these you can buy a cable that goes from the headphone socket into red & white phono plugs. This will only give you stereo sound. The digital method should give you 5.1 surround.
Old Jan 23, 2008 | 07:34 PM
Thrush's Avatar
Thrush
Irritating c........
Christian, first you need to see what the connections on the front are - inputs or outputs.... If outputs, when you right click on the desktop and choose PROPERTIES and go to SETTINGS, you should see two screens listed - one of these should be the analog output (s-vid or composite)
If you amp has video switching (as in, if it's an AV Reciever) it will most likely have composite and svideo inputs on it, so you should be able to plug into that, tho you will need a second lead to run from the AVR to the TV - so unless you are plugging in a few source devices through the amp, it will probably be easier to connect the PC directly to the TV. You will need a seperate audio connection from the PC to the amp. Not knowing what your soundcard is, typical output is a 3.5mm stereo jack (for 2ch left and right speakers), so use a 3.5mm stereo to twin RCA cable and hook it into your amp.
Now, not knowing what TV you have makes it hard to say what quality you will get. My TV is CRT, so I have to connect via S-Vid to it as it only has analogue inputs, and as such, the quality of "computer" stuff is awfull! S-vid, as far as I know, only allows a maximum of 1024x768 resolution (which is 4:3, like a typical "square" pc monitor), and will also do 640x420 (4:3) and 800x600 (also 4:3). As far as I know s-video doesn't support a 16:9 widescreen res (such as 1280x720) from computers. This *might* depend on your PC's graphics card and your TV of course!
If your TV is a digital TV (LCD or plasma) I would be tempted to use a digital connection - such as VGA or DVI. VGA (the blue 15pin connection) is actually analogue RGB, but is treated like a digital connection for use with TFT monitors, and LCD and plasma screens. DVI is a fully digital connection. Both will do full 16:9 widescreen resolutions, the pixel size of which depends on your TV. It will also give a FAR sharper picture meaning you will be able to read web pages, menu's etc.
Old Jan 23, 2008 | 07:39 PM
Thrush's Avatar
Thrush
Ah, more replies I see whilst I typed mine
Yes, as I said the 3.5mm jack output will output stereo only, and as said the digital output will output multichannel digital audio - but this is dependant on a) what soundcard software you use, and b) what video player software you use!
For example, a DVD rip or AVI will multichannel audiotrack (such as Dolby Digital 5.1) played in Windows Media Player will not output multichannel audio. But use a player like Media Player Classic, Zoomplayer or VLC, and after configuring it correctly you will be able to pass through multichannel audio from the film to the amp with no loss - the amp then decodes the bitstream and you get your 5.1 Dolby Digital or DTS. This is how mine is set up (although I use optical, the principal and practice is the same)
Oh, and SVHS was a (now defunct) format, not a cable. S-Video is not SVHS. Common misconception
Old Jan 23, 2008 | 07:55 PM
Christian and Beccy
#1 in Spelling Club
Fuck you know your stuff Thrush.
Right, here's what I have on my PC......
As you can see, the card where my PC Monitor connects also has an S-Video Connection and a DVI (??) connection. You can also see the Digital Audio connection points near the top of the board. Yah?
The front is fairly self-explainatory.
The Amp is an Onkyo SR674 and has this on the front.....
There is masses of stuff on the back, but it's a proper arse to get to now so, I'm hoping I can do this with what I have on the front.
The TV is a 32" LG 32LB1D LCD. It has lots of connectivity....
This panel is closest to the PC (so is favourite)
Followed by this one.....(I currently have the on-screen display connection from the Amp connected to the Yellow Video connection on the AV3 panel)
But also, there's these.....
The TV is about 2-2.5 metres from the PC. This is not something I'd want to use often, but hoping to have the leads coiled up behind the TV, then run them across to the PC when needed.
So, whats next!!??!!
Old Jan 23, 2008 | 07:58 PM
Christian and Beccy
#1 in Spelling Club
Oh, BTW, I have Windows Media Player, but usually use VLC.
Old Jan 23, 2008 | 08:02 PM
Alex_86's Avatar
Alex_86
for best image i would go for dvi to hdmi
Old Jan 23, 2008 | 08:05 PM
Christian and Beccy
#1 in Spelling Club
http://cgi.ebay.co.uk/3M-QUALITY-GOL...QQcmdZViewItem
St3V3_C's Avatar
St3V3_C
RGB in on the TV, every time. You can use that DVI output, and run the TV as a second monitor.
Your digital audio in on the front of the amp is optical, so not compatible with the digital coax out from your PC.
Two options:
1) Look on the back of the amp for a digital coax in (same as PC) - best option.
2) Use the 2 channel (L/R) inputs on the front of your amp and a 3.5mm output from the PC.
Depending on your amp, you might still be able to make all 6 speakers work, but it will only be stereo, not 5.1
Old Jan 23, 2008 | 08:07 PM
Christian and Beccy
#1 in Spelling Club
I dread pulling that Amp out!! It's location doesn't make it very easy to get to the back!! Oh well, I suppose I can plug the lead in and coil it up beside the Amp!!
Old Jan 23, 2008 | 08:08 PM
tonyk's Avatar
tonyk
Christian, looking at the pic, I think your best option is going to be DVI- to HDMI on that amp or DVI to VGA for your video signal. This will allow you to output a decent quality picture on your LCD/Plasma. I would then take the Audio from that orange port on the mobo to your optical port on the front of your amp. You will need to buy a Toslink converter box for Ł13.99 from Maplins. This converts the Coaxial orange port into a digital optical connection on your amp.
Took a while to type this, so probably beat to the punch!
Thrush's Avatar
Thrush
Right, here's what I would do;
1/ Use ONE OF THESE CABLES to connect your PC's DVI port (white one next to the blue VGA on the back) to the HDMI input on the back, marked "1(DVI)"
2/ Use ONE OF THESE CABLES to connect from the DIGITAL OUT on the back of your PC to a digital input on your Onkyo
3/ Use VLC (or Media Player Classic in conjunction with CCCP, or Zoomplayer - which lately I prefer to both - no idea if it responds to the remote control like MCE does) to play movies, and PM me if you don't get any 5.1 audio from it as I may be able to help you change the settings so you do
Old Jan 23, 2008 | 08:09 PM
St3V3_C's Avatar
St3V3_C
Maybe, but depending on the video card, you might end up with issues.
It's not going to be any better than the RGB socket unless the card is HD compatible.
Old Jan 23, 2008 | 08:13 PM
Christian and Beccy
#1 in Spelling Club
Thrush, how does that cable in the Ebay link look? I don't really want to spend a fortune on this.
Thanks EVERYONE for your help!!
Old Jan 23, 2008 | 08:19 PM
Thrush's Avatar
Thrush
You could use the RGB inputs on the TV (by RGB I pressume you are referring to the component inputs? If so, then RGB is the wrong term (another common misconception), as component is actually YUV, or YPrPb/YCrCp. RGB is actually closer to the analogue RGB found in VGA, and closer still to the RGB found in scart connections - which is three seperate pins for red, blue, green plus another for sync, plus another for luminence, whereas YPrPb has red blue and green phono connectors, but has to carry the sync on the green connector, and luminence on either red or blue - can't remember) but only if the PC supports RGB output from the VGA connection, and you'd need a VGA to 3 RCA cable.
Old Jan 23, 2008 | 08:22 PM
Thrush's Avatar
Thrush
C - it's the right cable, but for 99p it'll probably be shite It's a digital connection, so cable quality isn't the issue (passing 0's and 1's is much a sameness) but it's ther termination and quality of the two connectors thats important. But worth 99p if you just wanna test your rig for sure.
I only posted those links to show what you need - I wouldn't pay those prices either. I paid less than a fiver for a brand new 1m digital audio cable, so for a 3m (which I guess is what you need looking at the other cable you linked to) you will be looking to pay Ł5-Ł6 for one....
Old Jan 23, 2008 | 08:23 PM
Thrush's Avatar
Thrush
http://cgi.ebay.co.uk/3M-Digital-Coa...QQcmdZViewItem
Old Jan 23, 2008 | 08:50 PM
St3V3_C's Avatar
St3V3_C
No mate, the socket labelled RGB - which, as you say, is the VGA one.
Old Jan 23, 2008 | 08:58 PM
xr4x4rs's Avatar
xr4x4rs
i havnt read the whole thread but my mate has one of these i think
http://www.eclipsecomputers.com/prod...de=SKM-MV6000R
basically it links upto your tv and links upto the pc, so anything on the pc you can watch through this onto your tv wireless aswell i think
Old Jan 23, 2008 | 10:37 PM
aurallis's Avatar
aurallis
Dude fuck all that shit do you have a xbox or a ps3??????? if you do use
www.tversity.com and then all will work sweeeeeet assssss.msn me or pm if u want help setting it up.
Old Jan 23, 2008 | 10:42 PM
Alex_86's Avatar
Alex_86
yes it would
as the rgb signal is analog and the dvi is digital the image would be sharper than the rgb/vga image. the resolution would be the same yes, but watching a movie you will spot the difference
Old Jan 23, 2008 | 10:44 PM
Alex_86's Avatar
Alex_86
why do he need a xbox or a ps3 to watch a movie if the computer is already standing there?
2.5meters from the tv
Old Jan 23, 2008 | 10:47 PM
aurallis's Avatar
aurallis
because it saves all this wires and sound hooking it up etc and then u can watch any movies etc in any room in the house.Fantastic is all i can say solved all my problems and wires etc were no longer needed.Also pictures and music all controlable from the xbox or ps3 remote rather than hitting play over here etc just makes sence
Old Jan 23, 2008 | 10:53 PM
Thrush's Avatar
Thrush
Windows Media Centre (that Christian already has) also has a remote so is controllable rather than "hitting play over here etc"
Old Jan 24, 2008 | 12:07 AM
BillyCabrio's Avatar
BillyCabrio
Christian and Beccy
Yo!
BUY THIS!!! DVI-D to HDMi Cable
I bought one for my pc to tv and it works a foooooking treat
I just use the speakers and sub on the pc if i'm watching any films
Also.... https://passionford.com/forum/viewtopic.php?t=310955
Old Jan 24, 2008 | 12:11 AM
BillyCabrio
And i'm also going to use an Optical Cable for the sound, once i get around to it
Old Jan 24, 2008 | 05:53 AM
Dingy's Avatar
Dingy
best thing anyone can do is buy an xbox one...
Get it chipped...
Fit a 200gig drive, install slayer 2.7 then install xbmc and network share to ya pc....
Composite lead from the xbox to ya lcdtv and you have full hd streaming from any network resource in mint qual to ya tv.....
(scart lead also works LOL )
You can do this cheap - about 50-100 quid
and there you have a media centre that will play anything....and do loads of other stuff to
Old Jan 24, 2008 | 07:00 AM
Spiky's Avatar
Spiky
why is everyone saying dvi to hdmi? for the "slight"increase in picture?
it has PC INPUT on the tv, why dont he just use that, or am i missing something here
Old Jan 24, 2008 | 07:28 AM
BillyCabrio
Spiky
Prop cos the cables are the same price, so i just went for the digital one
Old Jan 24, 2008 | 07:33 AM
Spiky's Avatar
Spiky
i know that, but the PC input is the obivous one to use, as it designed for....................... PC input
Old Jan 24, 2008 | 07:44 AM
BillyCabrio
Ah yes that is true, why make anything easy for ourselves
Old Jan 24, 2008 | 10:41 AM
gingeRS's Avatar
gingeRS
is there any advantage to using DVI- HDMI over a VGA cable???
Old Jan 24, 2008 | 10:49 AM
Spiky's Avatar
Spiky
the logic in using a HDMI socket baffles me
Old Jan 24, 2008 | 10:51 AM
rsnissan's Avatar
rsnissan
dvi/hdmi is digital, VGA is analogue.
Old Jan 24, 2008 | 10:54 AM
Christian and Beccy
#1 in Spelling Club
So, lets do this a bit at a time......
Despite all the difference of opinion, can I first clarify that regardless of what I connect to on the TV, am I using the DVI port on the PC? Not S-Video?
Old Jan 24, 2008 | 11:00 AM
Spiky's Avatar
Spiky
you have a few options,
S-video... IMO crap picture
the DVI socket to HDMI..IMO pointless see below (unless you didn't have a PC input)
DVI (with vga converter) to VGA (RGB) input on TV
but either of the bottom 2 will be just fine
