gotech pro
Old Jan 23, 2008 | 01:28 PM
picky775's Avatar
picky775
Default gotech pro
Does anyone on here run gotech pro management on there fiesta/escort turbos (efi) with standard inlet manifold (not moddified) if so do you use your idle speed control valve??? any help would be appreciated thanx
Old Jan 23, 2008 | 03:45 PM
jessie_rs's Avatar
jessie_rs
i have mate who runs mfi pro not pro x and doesnt have idle control valve it runs off ignition timing but has never been right idled to high jamies sorted it but now wont cold start
Old Jan 23, 2008 | 06:00 PM
picky775's Avatar
picky775
ive just had the ecu sent back from jamsport they put a base map in it for me but it still wont run,it starts,runs for a few seconds then cuts out my idle control valve is not wired up so was wondering if it could be that? The gotech pro hasnt got a plug for the iscv so was wondering if i need to wire one in sumhow?? Also think it may be due to crank sensor,its a standard sensor from a 1.6 efi cvh xr3i,but dont know if a fiesta tubo one is different?? Its getting so frustrating now as its been off the road for 5 months till i could afford the management and now it still wont run,thinkin about giving up and breakin the thing
Old Jan 23, 2008 | 06:19 PM
NEEDFORSPEED's Avatar
NEEDFORSPEED
the sensors are the same was this loom not of a cossie? you need to get a gotech wiring diagram up so we can have a look and show you how to wire it you just have an ignition feed at the idle valve and a pwm output from the ecu. if it doesnt have an idle valve output then i wouldnt be fitting it!
Old Jan 23, 2008 | 06:22 PM
picky775's Avatar
picky775
Yes the loom was from a cossie but apparently there the same looms just use different plugs etc
Old Jan 23, 2008 | 06:26 PM
NEEDFORSPEED
so all the outputs are set the same ie the crank / phase sensor
NEEDFORSPEED
sorry just read youve got a map from jamsport so presume its a wiring problem then
Old Jan 23, 2008 | 06:37 PM
picky775's Avatar
picky775
yeh,got the ecu back this mornin with the fiesta turbo base map installed but still no cigar
Old Jan 23, 2008 | 06:38 PM
NEEDFORSPEED
does it fire? if not what have you lost? fuel spark or injection or everything
Old Jan 23, 2008 | 06:42 PM
picky775's Avatar
picky775
it fires up runs for about ten seconds then dies.
Old Jan 23, 2008 | 06:43 PM
NEEDFORSPEED
idles or you have to rev it? plugs black?
Old Jan 23, 2008 | 06:51 PM
picky775's Avatar
picky775
it idles for a few seconds but if you try and rev it it will die,plugs are normal not overfuelin.Im gettin fuel and spark but sumthins shutting it down will have to have a good luck at the wireing at the weekend as the instruction doesnt seem to corrispond with what ive got.
Old Jan 23, 2008 | 06:59 PM
big_wig_074's Avatar
big_wig_074
you checked for air leaks and you actually have fuel in tank?
Old Jan 23, 2008 | 07:01 PM
picky775's Avatar
picky775
yeh done all that its got near on a full tank of juice.
Old Jan 23, 2008 | 07:04 PM
big_wig_074
running an afm?is it connected correctly etc?
Old Jan 23, 2008 | 07:10 PM
picky775's Avatar
picky775
Im going to have a look over the weekend and check all wires as i went off my mates management wireing as its the same but looking through the manual i should have earths on 2 pin outs but i know i havnt done that in the car,also theres 2 black wires on my mates that were earthed but in my manual its sayin they should be positive 12v so its a bit backward at the moment.
Old Jan 24, 2008 | 09:00 AM
Ryan's Avatar
Ryan
wiring for the TPS correct?
Old Jan 24, 2008 | 01:02 PM
NEEDFORSPEED
should stil idle for more than seconds really
Old Jan 24, 2008 | 01:04 PM
Ryan's Avatar
Ryan
does it idle if you just leave it? i.e dont touch the thottle?
does it struggle then die? i.e rev slowly drop? or does it just cut out when instantly when left?
Old Jan 24, 2008 | 05:27 PM
picky775's Avatar
picky775
UPDATE; I checked fuel pump earlier and it had blown out its grommet on the holder so wasnt feeding the engine properly so sorted it out thinkin im a clever man tried startin engine again but still wont run i noticed puffs of smoke out the exhaust but couldt see what colour it was as it was dark by this time and couldnt smell it as it was blowing past the other side of the car i got an email from jamsport sayin all my wires were right so still got a problem somewere its like the engine is overfueling massively on start up but the ecu has just had a standard fiesta turbo map put in it so im puzzled about my next step now.i just feel like doing this to the car now
Old Jan 24, 2008 | 05:30 PM
NEEDFORSPEED
standard map .. what injectors and map sensor / sensors you using?
Old Jan 24, 2008 | 05:35 PM
picky775's Avatar
picky775
Its runnin standard blues and the map sensor is in the ecu.
Old Jan 24, 2008 | 06:06 PM
Jamie Going's Avatar
Jamie Going
jam-sport.co.uk
hello mate its jamie try disconnecting the tps and then see wat happens if it is wired wrong and it will make the 5v feed go to earth and sut the ecu down as protection
Old Jan 24, 2008 | 06:26 PM
picky775's Avatar
picky775
ive tried thet mate but still no go ive been speaking to mark as you may already know,i would bring it down to you but i just havnt got the cash yet ecerythin seems to be goin up in price council tax,gas,elec and now my rent so strugglin for cash at the mo
Old Jan 24, 2008 | 06:34 PM
picky775's Avatar
picky775
rite ive just gone out to the car pulled the tps off and tried starting it,the ecu power stays on as its crankin over and the first green led is flashing but the middle one isnt,i put the tps back on and tried again and now its crankin over power light on and first green led flashing but before it was trying to catch and run then the middle green led would flash but now its not
Old Jan 24, 2008 | 06:45 PM
crazycage's Avatar
crazycage
does it run and cut out still
crazycage's Avatar
crazycage
Old Jan 24, 2008 | 07:20 PM
picky775's Avatar
picky775
yeh
Old Jan 24, 2008 | 08:38 PM
jessie_rs's Avatar
jessie_rs
get it to jamsport mate tbh dont keep spendin money on parts u might not need
Old Jan 24, 2008 | 09:04 PM
picky775's Avatar
picky775
Totaly fecked off with it now realy,its taken me 3 years to build now the final stage and i cant figure it out and havnt got the cash to get it to jamsport so having a good think weather just to break it and sell it for parts
Old Jan 26, 2008 | 10:29 PM
picky775's Avatar
picky775
UPDATE; figured out that the fuel pump insnt delivering enough pressure so going to have another look at 2moz,a big thanks to RICK for giving up his day to come and spend a lot of time tryin to sort the car out 2 day top bloke
Old Jan 27, 2008 | 12:25 PM
crazycage's Avatar
crazycage
have you got a spare pump mate??
Old Jan 27, 2008 | 12:43 PM
picky775's Avatar
picky775
no mate ive just put a new piece of fuel pipe on and its startin runnin for a bit then shuttin down agai but it was more than we got yesterday plus its still runnin yopur map,rick is on his way back over
Old Jan 27, 2008 | 12:45 PM
crazycage's Avatar
crazycage
so its a reall 260+ bhp then lol , cool should run right when he puts it back on your standard map
Old Jan 27, 2008 | 12:48 PM
picky775's Avatar
picky775
yeh must be runnin around 3oo brake ha ha have you got a spare pump just incase this hose doesnt work??
Old Jan 27, 2008 | 12:49 PM
crazycage's Avatar
crazycage
no but was going to say we could try mine as long as it dont kill it tho
Old Jan 27, 2008 | 12:51 PM
picky775's Avatar
picky775
would probably kill it knowin my luck so think we will leave well alone you said you had put sum pipe on yours what pipe did you use to stop it from goin to jelly??? The petrol seems to have rotted the stuff that i used??
Old Jan 27, 2008 | 12:54 PM
crazycage's Avatar
crazycage
proper fuel pipe mate ive got some in the garage ill pop over with it later if you want im just getting something to eat
Old Jan 27, 2008 | 12:56 PM
picky775's Avatar
picky775
Thats what i used,well i think it was fuel pipe anyway,ive put sum proper fuel pipe on it now anyway so see how long it lasts
Old Jan 27, 2008 | 06:03 PM
picky775's Avatar
picky775
UPDATE: AT LAST ITS ALIVE!!!!!!!!! Im a verry happpppyyyyyyyyy man A GREAT BIG THANKS TO RICK FOR GIVING UP YET ANOTHER DAY AND GETTING IT SORTED just need bigger injectors now coz there maxed out already but at least after 5 months it actualy moves.MANY THANKS RICK FECKIN TOP BLOKE if anyone sez you dont know your stuff they dont know nowt
