COSWORTH 4X4 PROPSHAFT DONUT
Jan 22, 2008 | 08:33 PM
DOES ANY1 KNOW WHERE CAN I FIND ONE THERE IS A BEARING THAT SITS INSIDE AT THE BACK OF THE BOX AND THE END OF THE PROP
THANKS IN ADVANCE
Jan 23, 2008 | 04:37 AM
Hi ive seen em on e-bay buddy try there.
Jan 23, 2008 | 06:20 PM
I have got 1 that i was gunna use on my saff but never fitted it . Its the 50p shaped 1 with the bearing in the middle is that the one you are after ?
Jan 26, 2008 | 04:59 AM
I just bought one from Woodford Garage for around 60 pounds its called the Propshaft Rubber Coupling Part Number: 7189409....
Hope this helps!
Jan 26, 2008 | 06:48 PM
Depends which one it is that you need.... the 4x4 saff ones with the bearing in the middle are no longer available from ford
Jul 26, 2010 | 06:37 PM
Quote:
Originally Posted by
bunjeeman
Hope this helps!
This is the Escos one, Woodford can't suppy the hexagonal one.
Jul 26, 2010 | 06:46 PM
Think I may have a hexagonal one, used but still ok
Jul 26, 2010 | 07:05 PM
cos47
never available, only comes on a complete prop
escos/late sapph one needs the late sapph prop section, too
mk3 fiesta cosworth
Aug 23, 2015 10:31 AM
Anutternutter
Aug 21, 2015 06:07 PM
charliecosworth
Aug 19, 2015 02:00 PM
cossie4x4
Aug 14, 2015 06:29 PM
Aug 14, 2015 07:29 AM
