range rover abs pump were from help
any one now were i can get a abs pump for a range rover 4.6 v reg need one urgent now any links or of a were about thank you ..
brakes are just hard and if pushed you can get the pedal to the floor but the car still rolling to a very slow stop thers no leak and you cant here the abs pump working at al is ther a common fault with these cars as most i have spoke to also susgest the abs pump all fues and realys seam to work
Any motor factors should be able to do an ABS pump for it mate. Try Eurocarparts etc.
I've always found this lot extremely good for second hand Land rover parts:
http://www.cws4x4.co.uk/
Have you tried your local dealer? You may be surprised how cheap stuff can be if you pal them up a bit?
You know the electric window switch pack that fucks up? about £80 second hand from everywhere? I just got it for my P38 from Hunters in Guildford for £109 + vat. Worth paying a little extra for a genuine, new and guaranteed part
Alternatively, this is only a small business and they specialise in the EAS but you never know:
http://www.p38spares.co.uk
