Brake judder on new discs?
Old Jan 22, 2008 | 06:36 PM
cabbykarl's Avatar
cabbykarl
Default Brake judder on new discs?
Hi ppl, put myself a small upgrade of brakes on my MK5 Escort using Mondeo calipers and brand new RS2000 discs. All was fine for a couple of hundred miles but now there's a judder through the steering wheel when i'm braking.
I've only used the brakes hard twice just to test they work well, apart from that I brake well early but lightly all other times.
I've had new bottom arms on for about a 1000 miles now and put power flex bushes in them so they're like new.
The car's nice and smooth when off the brakes. The only things I can think of are perhaps the discs aren't flat on the hubs but then why were they perfect when I first drove it after fitment? If the hub(s) were bent the car would shake all the time at higher speeds. There doesn't seem to be any play in the steering but it's pretty stiff (non power steering).
Now the funny thing is the last brake setup (the car's original) did exactly the same shortly after fitting new discs and pads to the point where in about 3000 miles the car just about shook your teeth out when braking.
Any ideas/happened to you suggestions etc as i'm a bit stumped.
Oh the calipers are nice and free moving too so no binding etc...
Help! lol
Thanks.
Old Jan 23, 2008 | 11:40 AM
LHD220Turbo's Avatar
LHD220Turbo
sounds like you havent bedded the discs and pads in for long enough imo, difficult to diagnose sitting in front of a PC
Old Jan 23, 2008 | 03:28 PM
cabbykarl's Avatar
cabbykarl
Yeah I get your point it is pretty hard from in front of a computer. I'm just fishing for ideas peeps, thanks
Old Jan 23, 2008 | 07:45 PM
Dal_'s Avatar
Dal_
Does sound as though you haven't bedded them in right unfortunately
Either that or you've sat at traffic lights with your foot on the brake with hot pads / discs and warped them
Old Jan 24, 2008 | 04:38 AM
stevecossy's Avatar
stevecossy
As above they must be bedded in right and resist the urge to brake hard. Also my mate warped his by braking hard and then sat with foot on brake at the lights. Try some new discs and pads bud.
Nov 1, 2015 06:53 PM
locum8
Oct 1, 2015 01:50 PM
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
