Ford Classics & Vintage Discuss all other Ford cars here, from the classics to Vintage to the Australian and American Fords!
MK1 cosworth conversion
Old Jan 22, 2008 | 11:26 AM
jim jones's Avatar
jim jones
Default MK1 cosworth conversion
I'm doing a cosworth conversion on a MK1 escort and I was wondering what turbo to put on it. I was thinking of a T34 and just wonderd what people who have done this conversion in the past used to help me decide what the best turbo to use is.
Old Jan 22, 2008 | 03:01 PM
The car it is going in is irrelevant.
I always ask what poweer you want to have, if only 250 say no point in a T88, for example.
Keeping the smallest turbo that will do the job will both minimise lag and make the car more driveable.
Of course you then get into turbo mods such as different size compressor and turbine housings.
I wanted around 400 eventually so used a .48 turbine, with T34 trim wheel into a T3 machined housing(compressor), with the "usual" 360 bearing ans also step gap seal.
Mine has 150lbft at 1500rpm, but a lot of this is due to de shrouded head, cost of Ł275 and makes a WORLD of difference.
Ask yourself what sort of power and characterstics you want from the engine, this will decide for you what spec is best.
Old Jan 23, 2008 | 08:02 PM
graham c's Avatar
graham c
i ran a t3 with nos and that woz well quick, it dont weight anythink
Oct 9, 2015 07:38 PM
saph in dorset
Aug 14, 2015 10:10 AM
Aug 14, 2015 07:29 AM
