Fitting 2wd Drive Brakes To my Frst!!
Old Jan 22, 2008 | 09:37 AM
Flatoutjosh's Avatar
Flatoutjosh
Default Fitting 2wd Drive Brakes To my Frst!!
Hi sorry i am new to all this and am eager to enter your world of rs's!! I have a a frst and a set of cossie 2wd front 4 pots, Rumour has it that i need 4x4 discs however i have also heard another rumour that i can use 5mm spacers either side off 2wd drive discs but these are only rumours and am hoping that some1 can verify them for me please! Thank u!!
Old Jan 23, 2008 | 08:38 PM
frsjon's Avatar
frsjon
to be honest mate,your better off selling all you have and buying the 4x4 disc's and calipers....you can get the 2wd calipers to fit but have to grind parts down,and unless you change things like the servo and master cylinder you wouldnt notice any gain over the 4x4 stuff.....id say a big no no to the 2wd disc's though.... for one,putting all these washers on will mean there will be no bolt left to hold the wheels on.... i recon you should be able to sell the stuff you have and get enough to afford the 4x4 stuff...
Old Jan 24, 2008 | 02:26 PM
Flatoutjosh
Will I have to change the servo and brake cylinder for the 4x4 ones?? Whats the best to use if i do?? Do u no if the pads from 2wd are the same as 4x4 or is it wrth just getting rid of the whole lot ?? The pads and discs are fairly new loadsa meat on them so if i can salvage somet it mite be worth it if ya get me! Sorry loadsa ques!! Thanx for ya time tho!!!
Old Jan 24, 2008 | 03:40 PM
antony215's Avatar
antony215
Escort Rs Turbo
Im sure the fiesta is the same as the escort if thats the case then if you want 4+4 calipers you need 2wd disc's. If you want to use 2wd 4 pots then 4mm needs to be taken off the mating edge of the caliper, where it bolts onto the hub. The 4+4 way is easyer but the 2wd is ment to be better. Have a look here
https://passionford.com/forum/viewtopic.php?t=248404
or on here
http://www.rsbible.co.uk/
Old Jan 26, 2008 | 04:43 PM
frsjon's Avatar
frsjon
sorry for the late reply....all you will need is the 4x4 calipers ,disk's and pads...you will need to space the caliper from its mounting with a few washers so that the disk sits in the middle of the caliper.... get it all for a 4x4...
Old Jan 27, 2008 | 03:25 PM
mikee_rs's Avatar
mikee_rs
http://www.fiestaturbo.com/forums/ex...-pics-vt29615/
Dr. Ickxs
Aug 15, 2015 11:34 AM
cossie4x4
Aug 14, 2015 06:29 PM
track.focus'd
Aug 12, 2015 05:53 PM
Red_bull
Aug 9, 2015 08:34 AM
Old ford
Jul 31, 2015 06:50 AM
