s1 and s2 cylinder heads
Old Jan 18, 2008 | 08:00 PM
lee s1's Avatar
lee s1
Default s1 and s2 cylinder heads
hi all i am new here, i have got a poorly s1 and could do with a new head does anyone know if s1 and s2 heads are the same ? as s2 heads seem to be easyer to get hold of thanks lee
Old Jan 19, 2008 | 11:49 AM
moesin2005's Avatar
moesin2005
i think so
Old Jan 21, 2008 | 12:22 AM
Grandad racer's Avatar
Grandad racer
hi,now i may be wrong here, but iv always thought the xr3i head will fit an rs turbo. correct me if im wrong guys!!!
Old Jan 21, 2008 | 11:21 AM
G2RSR's Avatar
G2RSR
Bodybuilding
From: Cannot be identified by the information given.
yes they are the same but the exhaust ports are round on the S1 head but makes no difference
Old Jan 25, 2008 | 05:02 PM
rsturbowhite's Avatar
rsturbowhite
the heads are the same , wot seems to be the proplem with your head ther gone realy go wrong
Old Jan 26, 2008 | 08:21 PM
lee s1's Avatar
lee s1
Hi it has had a big valve convertion to 45mm inlets allso a stage 3 port and polish and has cracked between all 8 valves it also has a very large hole on piston no 4 and had just sent the haed off to be checked before i put it back together.so i have hit another obsticle.
so a series 2 head should go straight on no messing ?
Old Jan 26, 2008 | 10:09 PM
picky775's Avatar
picky775
Yes mate will bolt straight on
Old Jan 27, 2008 | 11:34 AM
Barry R's Avatar
Barry R
i have got a spare s1 head if you need 1 its has only done a gen 32k
Old Jan 31, 2008 | 07:50 PM
lee s1's Avatar
lee s1
i think i have found one but how much do you want for it ?
Old Feb 1, 2008 | 08:38 AM
mikedaf2's Avatar
mikedaf2
s1 and s2 heads are the same as far as fitment goes but you should be aware that the s1 head has softer valve seats as it was from 1986 that they made them unleaded so a very early head may need new valve seats to use unleaded.
i would get a s2 head if i was you
Old Feb 1, 2008 | 06:38 PM
Barry R's Avatar
Barry R
50 nicker plus postage my friend
Old Feb 2, 2008 | 08:26 PM
Maki's Avatar
Maki
Get any 1.6 mfi CVH head, they all the same, but use your old cam, pulley and valves
Also I'm with mikedaf2 he's right about late heads... better get one from MKIV 86-89 car
Nov 1, 2015 06:53 PM
