Warning Light after changing ignition coil.
Old Jan 17, 2008 | 07:23 PM
steve1111's Avatar
steve1111
Default Warning Light after changing ignition coil.
Hi all,
My wifes fusion, 1.4 03 reg stated to misfire at low revs. so i changed the plugs and the coil and this cured the problem. But the engine management light has stayed on and i dont know if this needs to be reset or if a different problem remains. Is there a way to clear this light myself or does it need to go to an expensive 'expert' ?
Steve.
Old Jan 17, 2008 | 07:43 PM
Try and take the car to a back street garage . Alot of these garages have the scanners which can be plugged in to check the fault. No doubt the light hq only on cause of the old faulty coil.
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
cameron2
Aug 25, 2015 07:18 AM
dojj
15
Aug 18, 2015 08:21 PM
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
Neatrags
Aug 16, 2015 07:57 PM
