Pectel board???? cosworth
Old Jan 27, 2004 | 07:14 PM
Default Pectel board???? cosworth
Will a pectel board in an L6 ecu fit in an L8 ecu????
Old Jan 29, 2004 | 09:58 AM
BTTT
Old Jan 29, 2004 | 11:28 AM
Guinnless's Avatar
Guinnless
I doubt it Nikki.
Stu will be the man to confirm this.
Old Jan 29, 2004 | 10:33 PM
ECU Monitor Enthusiast
NO NO NO
Old Jan 29, 2004 | 11:46 PM
Thanks for your help....no need to laugh at me though was there?
Old Jan 30, 2004 | 08:09 AM
I wasnt laughing, have a look those EMOTICONS are crying !!!!
Old Jan 30, 2004 | 10:39 AM
I stand corrected! How's your cossie btw after the Bristol mishap???
Old Jan 30, 2004 | 10:44 AM
Stu @ M Developments's Avatar
PassionFords Creator
Well.
Depends on how the L6 has been fitted with Pectel encryption TBH.
The most common way is to convert her to what Pectel call Level 600.
This was essentially a Pectel CPV2 issue 2 board but was changed slightly for the address points used with 6 and 600 software respectively.
The L6 if fitted with this item, will have a small set of modification's made to the motherboard. The most obvious of these is the addition of the 4 way riser connection on the left hand side of the motherboard. This will be connected to your level 600 board.
If this is the case, then YES. it will run with Level 8.
However, its better to get a Pectel CPV 2 Issue 3 with a genuine level 8 as there are fundamental differences in the system that make it both faster and more reliable.
The chioce i guess, is yours.
P.S:
Simon,
I know most folk dont know this, but we seem to have taken to using as meaning "laughing so hard im crying" Just to save any confusion in the future I always use this for crying:
Old Jan 30, 2004 | 10:46 AM
One more point though whilst im here:
The Pectel board in most 600s, and 95% of Level 8 units is PURELY for encryption. So you may not want one anyway.
If you need to know anymore, please call me on the number below.
Old Jan 30, 2004 | 04:30 PM
Originally Posted by Stu @ M Developments
P.S:
Simon,
Cheers Stu, I am still learning !!
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
hopper350
Sep 4, 2015 12:53 AM
