Small Electrical Issue.
Old Jan 14, 2008 | 10:38 AM
Damien.'s Avatar
Damien.
Default Small Electrical Issue.
Well i got my beloved car back yesterday, but with it came 1 small electrical issue. The rear window de-mister doesn't work any more.
Something i have noticed when i stick the car in reverse, the light on the button flashes for a split second.
Any idea's ?
Thanks, Damien.
Old Jan 14, 2008 | 12:11 PM
Sounds like a dodgy connection, possibly on rear tailgate pins/pads.
Old Jan 14, 2008 | 12:54 PM
Damien.'s Avatar
Damien.
Sorry to sounds stupid, what connections should i check ?
The one that plugs into the window connection ?
Old Jan 15, 2008 | 12:42 PM
Damien.'s Avatar
Damien.
Anybody ?
Old Jan 15, 2008 | 12:53 PM
I am sure th later escorts like yours use a PIN/PAD arangement between the tailgate and body, these often get cruded up, so a clean might help.
Lift up the tailgate and you will see 2-4 pins sticking out that go onto a pad of contacts when it is closed, try cleaning these.
Old Jan 15, 2008 | 03:34 PM
Damien.'s Avatar
Damien.
Ok, ill give that a go tonight.
Thanks.
Nov 1, 2015 06:53 PM
fordrallycar
Sep 30, 2015 07:57 PM
Fudgey
21
Sep 30, 2015 06:19 PM
stevecfrst1
Sep 30, 2015 05:18 AM
youngben
Sep 27, 2015 09:37 PM
