Brake dis sizes on cosworth
Old Jan 12, 2008 | 07:56 PM
capri280's Avatar
capri280
Default Brake dis sizes on cosworth
brake disc sizes
What are the standard factory diameter and type ie solid/vented on the following types of cars from the cosworth range
2wd cosworth
3dr cosworth
RS500 cosworth
Thanks
eugene
Old Jan 13, 2008 | 07:52 AM
All 283mm diametre by 24mm thick, FRONT VENTED
All 273mm diametre by 11mm thick, REAR SOLID.
One of my brake books says 3 door rear were 253mm, but I think they were as others 273mm, 253mm were non cossie.
Old Jan 13, 2008 | 12:35 PM
capri280's Avatar
capri280
Default brake
thanks tabs
Old Jan 13, 2008 | 01:29 PM
No probs matey, 4wd are as escy front 278mm vented, rear 273mm vented.
s1cab
Jul 26, 2018 06:11 PM
borboyous
Aug 22, 2015 11:17 AM
Aug 14, 2015 07:29 AM
Bosch
Aug 4, 2015 05:14 PM
