COSSIE PISTONS
Old Oct 13, 2004 | 07:07 PM
Jim Green's Avatar
Jim Green
Default COSSIE PISTONS
Just out of interest.........
Most engine builders seem agree that genuine Cosworth Racing Pistons are the probably the best (Without going over the top).
But what other options have we.
What is the differnece between Mahle 4 x 4 pistons and 2wd ones...?? Other than the offset gudgeon pin. Is there any difference to the comp ratio ??
And what are the other options and what Comp Ratio are they available in. Or does one have to machine their pistons to get a particular cr.
Just thought it might give some idea's to people building up new bottom ends and give them some choices of pistons and cr's.
And of course which is suitable for what ....... BHP Levels.
I know there's plenty of makes producing pistons now for the cossie.
Mahle
Cosworth
Accralite...... Just to name a few.
Old Oct 14, 2004 | 09:42 AM
Ian2wdsaffcos's Avatar
Ian2wdsaffcos
Hi Jim,
Long time no see! Hows things? I assume you're away again?
I can only really answer one of those questions............the 4x4 Mahle is slightly lower compression than a 2wd one, it has more of a bowl in them. When used in conjunction with a std 2wd(only 1 light precautionary skim done in it's life) it lowered my c/r to just over 7.7:1
HTH's
Cheers,
Ian
Old Oct 16, 2004 | 04:45 PM
Jim Green's Avatar
Jim Green
Thanks Ian...........Interesting.
I'm due back in the UK in about a week, and by then Karl will be well into the work on my cylinder head, fitted with his cams, and the turbo (t4) re-spec'd to suit.
Looking for genuine 400bhp.
Or he's fired.........
Old Oct 17, 2004 | 01:29 PM
Ian2wdsaffcos
Cool
Bet ya can't wait!!
What you getting done to the head? Ported & polished to Norris low-lag spec like Matt's?
Old Oct 17, 2004 | 02:10 PM
rapidcossie's Avatar
rapidcossie
je pistons are good!
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
deathrider666
Sep 28, 2015 06:12 PM
cossie330
Sep 27, 2015 04:13 PM
