what s the best oil to use in my s2?
I can assure you at £20 a pop it's not a true synthetic but a "hydrocracked" oil labelled (legally) as synthetic. See my posts concerning true synthetics and labelling.
If it works it works but don't be fooled by the buzzword "synthetic".
Simon
Simon
Use mobil 1 motorsport 15/50w you cant go wrong its 100% fully synthetic it costs around 35 quid. I use it in my motor and will not use anything else. I want to look after my engine as its only done 4500miles on rebuild. Also if you speak to Burton Power they will tell you the same. If you have spent alot of time and money on your engine then use the expensive fully synthetic oils so your engine will last
well never had any probs and if its good enough for schumacher's fezza its good enough for my rs!..lmfao!...it works its quiet and all is well! and puma build also use it on there engines and servicing so cant be that bad!
Originally Posted by K3V HA
I use 10/60w Castrol RS, got a great deal and service from Reyland Motorsport!
Simon.
Older engines with their larger operating clearances demand the higher viscosity oils to achieve an adequate oil film thickness. Using a modern low viscosity oil in engines could be a recipe for disaster with a danger that the oil film will break down in the bearings, allowing metal to metal contact to take place with the inevitable consequences !
hmmmm interesting info there Simon!!!
is it true that once you have started using Castrol RS you shouldn't swap to another brand something to do with different makeup pulling sludge thru or sumthin?
also could you PM your pricelist (+P&P)
cheers fellas went with mobil 1 motorsport in the end 35£ halfords
question for you all my engines making a very slight tapping noise on start up only gets a bit quiter when its warmed up?is something going?also is there any good tuners near milton keynes? cheers
Myn does that to im sure its nothing to worry about. But then again i dont use my TURBS every day which is probaly the reason why and if the engine hasnt been running for a few days then the oil drains back in to the sump
Simon.
Pm sent fella.
Simon.
Simon.
deathrider666
Sep 28, 2015 06:12 PM
