Transient fuelling?
Old Oct 13, 2004 | 04:10 PM
gingeRS's Avatar
gingeRS
Default Transient fuelling?
how does this work on a series 2 rst??? k-jet
i noticed since i unplugged my cold start injector the car has started alot easier in the mornings, idles a little lower but runs fine. one problem has reared its head in that sometimes when you dip the clutch to come to a stop in traffic the car stalls. it starts up easy enough just gets a little annoying after the third or fourth time.
any way to fix this, or any ideas whats causing it???
cheers for your help
rory
Old Oct 13, 2004 | 04:15 PM
Oranoco's Avatar
Oranoco
If you've got a dumpvalve on your car lob it away mate
Don't have the cold start connected on mine either mate and don't have the symptoms you've described
Old Oct 13, 2004 | 04:16 PM
Stu @ M Developments's Avatar
PassionFords Creator
What on earth has any of teh above got to do with Transient fuel correction?
Old Oct 13, 2004 | 04:19 PM
extra17's Avatar
extra17
i feel an essay coming on
Old Oct 13, 2004 | 04:21 PM
Oranoco's Avatar
Oranoco
Originally Posted by Stu @ M Developments
What on earth has any of the above got to do with Transient fuel correction?
I ain't clever enough to know what the fook it is mate
Old Oct 13, 2004 | 04:23 PM
Wasnt aimed at you fella
Your idea will probably fix it pal
Old Oct 13, 2004 | 04:24 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Transients?
Isnt that homeless people?
Nah, thas Vagrants
Transients? Posh word for gyppos innit?
PhilM's Avatar
PhilM
PassionBMW.com Member
Any chance you could state how the S2 deals with transient fueling though Stu, the question had me thinking! lol.
Old Oct 13, 2004 | 04:26 PM
Oranoco's Avatar
Oranoco
Anybody able to put it into thick mans terms so I know what the fook it is?
Old Oct 13, 2004 | 07:41 PM
gingeRS's Avatar
gingeRS
dont worry, may be to do with the dump valve
sure stu will fill you all in on what transient fueling is. i thought it may have summit to do with this.
come on stu tell all
Old Oct 13, 2004 | 07:42 PM
gingeRS's Avatar
gingeRS
p.s. does the d/v controller you sell at ms developments prevent this from happening???
cheers
Old Oct 13, 2004 | 10:38 PM
JesseT's Avatar
JesseT
The air plunger has a potentiometer attached to its axle. The rate of change of this value is measured by the fuel ecu and transferred to current for the electro-magnetic pressure actuator. This changes the control pressure and makes the plunger go deeper giving more fuel for the measured amount of air.
The Sludge
Technical essay Archives
28
Dec 30, 2008 09:00 PM
doggydowg
Apr 6, 2005 11:52 AM
s2_rsturbo
Dec 18, 2004 12:13 PM
