cam timing
Old Jan 8, 2008 | 06:21 AM
pieterjan's Avatar
pieterjan
Default cam timing
Hi
How do you do a proper cam timng on a sierra cosworth whit vernier pulleys?
I read a few artikels but there a a few methodes to do it but wich one is the best to do?
Old Jan 8, 2008 | 06:37 AM
It doesn't matter HOW you do it so long as you end up with the correct timing cam wise, as result is the same,
Normally qouted full lift after TDC etc.
As it is vernier anyway just put on this as will most likely be adjusted to best power driveability anyway.
Old Jan 8, 2008 | 07:30 AM
dave green's Avatar
dave green
set the vernier to 0, then as above
dave
RUBY123
Oct 22, 2023 12:04 PM
Danielbetty
Oct 3, 2015 06:01 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
taylora1409
Aug 12, 2015 12:06 PM
