Water injection ?
Old Jan 6, 2008 | 03:34 PM
Mad Matt's Avatar
Mad Matt
Rally nut
Default Water injection ?
I need to build the circuit for my water injection inside the intercooler, which water pump, water tank do you recommand me ?
Old Jan 11, 2008 | 08:43 AM
oldford's Avatar
oldford
I would recommend the Group A set from Ford Motorsport.
This is the only thing I know that worked. It is not cheap however.
It consists of a 10 liter tank, 2 supply pumps and a large high pressure pump.
You do need the nozzle from this set and a couple of valves. Anything else I found not to work properly and can damage the engine.
A cheaper version is water spray. You spray water to the front of the intercooler. This way you don't need the high pressure pump and the special nozzle. Any small pump (like a pump from the windscreen washers) will do.
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
DAZZER
Sep 30, 2015 08:43 PM
