Steering wheel wobble
Just bought myself an Ecos and I get a wobble through the steering wheel around 50mph. The wheels have been checked and balanced and the wobble is still there. I have been advised by a friend that the CV joints on the front may need replacing or possibly a bush has gone. I will be looking at this next week but wondered if there is anything else I should look out for.
Dave
Dave
I have the same problem, its not under braking. I checked all balancing as you did.
Check you power steering bottle level, mine has a strange problem of throwing the fluid out the top, I just left it, then the wobbling appeared. I topped it up and it stopped.
Do that....
let me know
Do that....
let me know
Originally Posted by truthordare
It's most probably the anti roll bar/track control arm bushes, if they need replacing, make sure you use poly bushes as the standard ones are pants.
Debs
Debs
ossie cossie
Sep 21, 2015 05:07 PM
Adam Graham
Sep 6, 2015 06:04 AM
