Escort Cosworth eeciv wiring help needed
Old Jan 5, 2008 | 07:08 PM
Escort1.8si's Avatar
Escort1.8si
Default Escort Cosworth eeciv wiring help needed
Hello
Im making a conversion on my escort cosworth involving a megasquirt ecu and a adaptor board to fit on the stock harness.
My problem is I connected everything like it should be but the engine wont crank at all.
It sounds like the fuel pump relay is coming in a few sec once i turn the key and goers off. I was wondering if it could be the pats module causing this problem, I have been told it would not cause any problem with pats as the ecu dont have to be recognized like a original ecu. Or is there maybe a wire that should be earthed that i didnt get? I have earth on wires: 16,20,40,46,49,60 in the ecciv plug
If anyone know where i can get a engine wiring diagram it would be mutch apreciated, i have been using one for the escort 1.8.
Old Jan 8, 2008 | 06:23 PM
Escort1.8si
Everything sorted, engine started on first crank
Old Jan 9, 2008 | 09:20 AM
Yura's Avatar
Yura
I look for wiring diagram for small turbo escos too. Any help please!
Old Jan 10, 2008 | 09:30 PM
Escort1.8si
I can send you some wiring diagrams, just tell me what you need
Old Jan 11, 2008 | 07:16 PM
Aaroncast's Avatar
Aaroncast
e mail me/wiring diagrams!!!---------theofficial3@hotmail,com
Old Jan 27, 2008 | 09:41 AM
Yura's Avatar
Yura
I need engine wiring diagram!
Thank you mate!!!
Escortdriver1
Jul 31, 2015 02:36 PM
Old ford
Jul 31, 2015 06:50 AM
