BATTERY & OIL GAUGE PROBLEM
the voltmeter doesnt work and and the oil gauge read off the scale, any idea anyone
the boost gauge works fine, were is the volt meter feed from
cheers wenny
cheers wenny
you've not disconnected the oil pressure switch or that recently have you?
When I fitted my new loom at first the gauge and warning light were connected the wrong way round - and the oil pressure gauge read off of the scale...
havnt checked the battery yet but the oil gauge worked fine till i snaped one of the terminals off, got another off martin and it does this, if the wires go on the other way round, i have no oil light and the gauge doesnt move at all
thanks for the wiring diagram kjc300
