FAO SECS
Old Oct 13, 2004 | 11:02 AM
ImaRacing 700's Avatar
ImaRacing 700
Default FAO SECS
I feel this is a public question....
S8...i notice you can fault test to see if the injectors are working,all 8 of mine are
If one injector fails say doing 7000rpm in 4th will the ecu send the engine into limp home mode quick enuff to avoid any damage?...As i am assuming a fault code will come up and cut power?
Old Oct 13, 2004 | 05:14 PM
ImaRacing 700
Simon...where art thou?
I dont call this good service..ROFL
JOKE!!
Old Oct 13, 2004 | 05:17 PM
PhilM's Avatar
PhilM
PassionBMW.com Member
Phil, he has a phone number
He's been busy today
Old Oct 13, 2004 | 05:18 PM
extra17's Avatar
extra17
phil he cant sit on here and wait for you all day lol, try the phone
Old Oct 13, 2004 | 05:22 PM
ImaRacing 700
You'd be proper fucked if you choose him as a phone a friend
JOKE!
Old Oct 13, 2004 | 05:23 PM
extra17's Avatar
extra17
PhilM's Avatar
PhilM
Why would you??? He answers his phone.
Might be fucked if you use him as your "message on a BB friend" though, because he works for a living, lol.....unlike some of us lucky ones who can sit on ehre all day
Old Oct 13, 2004 | 05:24 PM
ImaRacing 700
Listen you :gimps: its a general question for everyones information...it is NOT an urgent question..hence why on this occassion i dont need to use the phone
Please get off riding his dick
Old Oct 13, 2004 | 05:55 PM
Disabled Account's Avatar
Disabled Account
He is on his way back from an engine dyno session.........top day for S8 - yet another HUGE power YB engine
Sorry, I cant say any more than that for now
He will be posting up the dyno results later this eveinig Phil, so i am shure he will respond to this topic too
Old Oct 13, 2004 | 06:33 PM
ECU Monitor Enthusiast
Phil, Yes normally, the S8 will CUT a whole cylinder if it detects an electrical failure
on one of the two injectors for that cylinder and give a fault code.
This test is only done if the second injector is active at the SAME time as
the first one in any one fuelling cycle.
However, YOUR particular ecu is an out of date one which you are borrowing until
you decide to buy one properly as I have said I will exchange it when you do this.
This older version does NOT have that injector check feature enabled.
So dont try it !
I should add, ALL weber/pectel modified 8 injector ecu's do NOT have
this feature at all.
Old Oct 13, 2004 | 06:36 PM
ImaRacing 700
Yes it does mate...as i tried it and it works a treat!! ...You even told me in the instructions to fault check the injectors???
Old Oct 13, 2004 | 06:38 PM
Disabled Account
I know
Old Oct 13, 2004 | 06:49 PM
Glad it does work, must have sent you the wrong one
pabloXR
Sep 21, 2015 12:42 PM
Bailes1992
Sep 3, 2015 02:17 PM
K42L
Aug 28, 2015 01:23 PM
Bailes1992
Aug 16, 2015 07:14 PM
88_WRC_Replica
Jul 22, 2004 03:03 AM
