SOLD
Old Jan 4, 2008 | 10:26 AM
silky16v's Avatar
silky16v
Get on That!
Default SOLD
MSD Stage 3 Chip for L8 on T34, 803's (greens) & 3 bar for standard comp engine £150
Turbo Technics (P/N:S114) T34 Hybrid Turbo with 0.55 Exhaust Housing, cut-back blades, left hand threaded shaft no smoke or play in the shaft £350
Radtec 50mm RS 500 Intercooler £200 (provisionly sold)
Mongoose Full 3" Stainless complete with all box's & 3" rolled out tail-pipe £200
6 month old 4x4 Koni's & Chassis Dynamic -25mm Springs £175
Good standard Radiator & Fans £70
L8 Ecu complete with Standard Baby Board (Green stickered) £200
2x sets of Bosch 803's Greens fully flow checked £100
Engine is a 200 block rebuilt by PJ motorsport in 2004 with 0.50mm oversized Standard Comp Pistons, ARP Stud & Nut, new bearing threw-out
No wear marks on the bores and Honing marks still visable, engine was perfect running no smoke or knocks, car was running a MSD Stage 3 chip and holding 23psi of boost & drove home fine on thursday nite
Bottom-end complete with stud & nut £1000
OMP Strut Brace £25
Will updated with more parts tomorrow
All other parts also available the car is an Ebony Black 1992 4x4 Saph
let me know what you need all parts located in North West Cumbria
Postage available on all parts @ extra cost[/img]
Old Jan 4, 2008 | 02:22 PM
saph-mad's Avatar
saph-mad
Default COSSIE BITS
DO U HAVE THE FRT BUMPER ?
Old Jan 4, 2008 | 02:25 PM
Kelv's Avatar
Kelv
Almost there!
have you got usable front discs and calipers?
and vague price pls matey.
Old Jan 4, 2008 | 02:41 PM
silky16v's Avatar
silky16v
Get on That!
Default Re: COSSIE BITS
yes it has been marked on the drivers side but i will get a photo tomorrow and put it up
Old Jan 4, 2008 | 02:42 PM
silky16v's Avatar
silky16v
Get on That!
yes it has got drilled & grooved front disc's and pads about half way down once removed tomorrow i'll get a pic for you
posted it'll be £75.00
Old Jan 4, 2008 | 02:43 PM
Kelv's Avatar
Kelv
Almost there!
Cool.
just pop a phone number over when you get chance mate and ill call and sort out funds with you.
its for the misses's car anyhow.
Old Jan 5, 2008 | 07:12 PM
silky16v's Avatar
silky16v
Get on That!
have removed most parts today will remove rest tomorrow and do a big update
Old Jan 6, 2008 | 06:25 PM
2wd's Avatar
2wd
you will have a PM shortly..
Old Jan 6, 2008 | 07:45 PM
cameron2's Avatar
cameron2
Price for glovebox pls.
Old Jan 6, 2008 | 08:37 PM
gil's Avatar
gil
any play in t34 shaft
Old Jan 7, 2008 | 12:01 PM
silky16v's Avatar
silky16v
Get on That!
sorry it was damaged
Old Jan 7, 2008 | 12:03 PM
silky16v's Avatar
silky16v
Get on That!
nope none at all perfect working condition has Turbo Technics
Part No: 114
Old Jan 7, 2008 | 06:06 PM
jaimesdna's Avatar
jaimesdna
how much for the head & what is the thickness?
Old Jan 8, 2008 | 08:15 AM
silky16v's Avatar
silky16v
Get on That!
i kept the head it had just been full rebuilt and measured 138.66mm
If you are need of a 4x4 head PM me and i'll let you know where there is a good head that measures 168.71mm
Old Jan 8, 2008 | 09:15 AM
Yura's Avatar
Yura
silky16v
But I see T34 Garett at your photo...
Old Jan 8, 2008 | 09:50 AM
silky16v's Avatar
silky16v
Get on That!
Originally Posted by Yura
silky16v
the turbo is a T34 unit with 360 deg bearing, lefthand shaft, cut-back blades, and a 0.55 exhaust housing
Turbo Technics call this a T35 Hybrid Unit
Old Jan 8, 2008 | 10:56 AM
Yura's Avatar
Yura
silky16v
sorry but I dont understand. at the comr housing I see GARETT die on the photo. Which part of turbo made by Turbo Technics?
Old Jan 8, 2008 | 05:12 PM
silky16v's Avatar
silky16v
Get on That!
Upski
Pictures added for Injectors and MSD Chip
Old Jan 8, 2008 | 06:43 PM
Twellsie's Avatar
Twellsie
do you have the plastic bit of trim that goes around the gear lever and houses the leccy window switch, is it
a, Unbroken
and
b, Black?
Old Jan 8, 2008 | 07:43 PM
RST's Avatar
RST
u have pm
Old Jan 8, 2008 | 09:21 PM
westus1's Avatar
westus1
Default cosworth exhaust
silky16v
is the price of exhaust include posting
Old Jan 8, 2008 | 09:54 PM
mechanic28's Avatar
mechanic28
is that 200 block a proper ford one?
Old Jan 9, 2008 | 07:57 AM
silky16v's Avatar
silky16v
Get on That!
Default Re: cosworth exhaust
Originally Posted by westus1
silky16v
nope sorry postage not included
Old Jan 9, 2008 | 07:58 AM
silky16v's Avatar
silky16v
Get on That!
yes it is a ford block it is the original block the car was fitted with from the factory
Old Jan 11, 2008 | 09:03 AM
silky16v's Avatar
silky16v
Get on That!
Bump!
Old Jan 13, 2008 | 05:05 PM
KSA-Cossie's Avatar
KSA-Cossie
You have pm m8.
Old Jan 15, 2008 | 01:43 PM
Enigma666's Avatar
Enigma666
Turbo still for sale?
Old Jan 20, 2008 | 07:23 AM
cameron2's Avatar
cameron2
Hi mate, im after a strut cup. The 1 that sits on the shocker under the arch. Pm price pls
Old Jan 29, 2008 | 11:55 AM
TurboShed's Avatar
TurboShed
Cossiemodo
Need 4x4 starter motor, and glove box hinges.
Old Jan 31, 2008 | 05:16 AM
pieterjan's Avatar
pieterjan
Hi i need the distributor want you send it to belgium?
Old Feb 18, 2008 | 05:28 PM
RS SHAUN's Avatar
RS SHAUN
you still got a L8 ecu mate
Old Feb 18, 2008 | 07:07 PM
richard youll's Avatar
richard youll
do you still have the strut brace?
155lee
Oct 27, 2015 04:55 AM
155lee
Oct 24, 2015 11:11 AM
fordrallycar
Sep 30, 2015 07:57 PM
Ade
Alloy wheels and ICE for sale
Sep 7, 2015 05:06 PM
