BIG UP Fiesta Cos DAN "fiecosdan" Guys A legend
Just wanted to let Everyone know what a top bloke Fiecosdan is and how i can not recommend him highly enough to any and everyone who needs anything from general mechanics to fabrication work to even mild mapping
i have been to dan a few times in the past but when i got my car back and thought i was only running 0.8 bar i had no choice but to call dan up on Christmas eve
as i had a track day "donno" on the 27th of December
after a pressure test dan found that i had a few boost leeks and after a few hours sorting out minor ones some caused by me and some not we had the car boosting back at 1.8 bar holding 1.5
I then asked Dan if he would like to come to Donno with me and even offered to pay for him to be a passenger as he had been working on my car, not expecting him to come as a on call mechanic he put it on himself to load the car up with numerous tools and spares anyway
Disaster struck at donno in the way of low oil pressure and gear box problems
dan did try and drop the box to get me back out on track but unfortunately the whole box had to come out
28th at about 1:00 pm i rolled round dans with the car and we set about sorting out the box
a few hours later and the box was out
the problem was the gear selector cradle that sits on the top of the gearbox had come loose, whoever tightened it up last went a little over the top and what with aggressive gear changing it had just worked its way loose
there was only 1 fucked but we decided to Heli coil all 4 the top and side blots that was knowing it would never happen again
while dan was getting busy under the car i had a thought about my breather setup and the breather pipe that is meant to go to a catch tank has always fed straight back into the inlet
on the track even with the new engine in there is a puff of smoke and im willing to be my bottom dolla that the reason for this is due to the breather chucking oil thought the engine
did go to here
now blocked off
i had to make some sort of catch tank and check this out
Like a glove
also not to waste the Aeroquip i nicked a breather pot from dans gearbox that will hold fluid when its chucking it out it can go in the pot and then when it cooled down / Stops it can run back in the transfer box not needing to top it up
the hole
Dan modding the cradle to take the pipe
all on and in place
Breather pipe fitted and in position
Had to take the down pipe off to get the box out anyway so why it was off dan said i may as well have another boss fitted as i can check the AFR and have the defi Ex Temp in at the same time
once dan started to put the box back in and the car back together i got busy with some heat wrap as me and Goldbum wasnt sure if the exhaust was boiling the gearbox oil when the anti lag was on
either way its i had a load of it and it cant be a bad thing
Random jubilee clips got the job done
all fitted in
rear diff hanger pick
random shots
well at 2:30 the car was back together and ready to go
Like i said i cant thank Dan enough he is a Star and please anyone needing any work done on there car that they feel they are not 100% on Dan is more than Capable as you can see from the Above
Ben
as i had a track day "donno" on the 27th of Decemberafter a pressure test dan found that i had a few boost leeks and after a few hours sorting out minor ones some caused by me and some not we had the car boosting back at 1.8 bar holding 1.5
did go to here
now blocked off
Like a glove
the hole
all on and in place
all fitted in
random shots
Ben
Oil is down to being 10/40 semi running in oil which needs changing for 10/50 or 60 fully
i hope
has been fine since to be honest was only when i was caining the cnut out of it with goldbum it become a problem
has been fine since to be honest was only when i was caining the cnut out of it with goldbum it become a problem Trending Topics
i remember seein a post of one of dans exhausts he made for hes fiesta, the work he done on it was very well thought out and done for the job and also very tidy
i plan to have some work done by him in future,, seeing this post though shows me hes VERY VERY hard working and even more smarter than i already thought he was
Originally Posted by miller3
Well done Dan mate' I can imagine you will now have a lot of private work coming your way
Grete guy well done pal
as long as he can still make time for me
Dan seems the kind of guy to thrive off stuff like this so im sure he wont mind in the slightest
. I on the other hand have become very lazy
.. Monday to Friday is enough for me lol
Fiecos Dan no worries Dan
cossie4i is what hes allways like
and i got a Tea after you wen
even if it did taste like Caramel
turboboss just see your post wanted to pop down and say hello but have been to unwell
jay you got it mate
jay you got it mate
Originally Posted by cossie4i
He was giving too much lip for my liking the other day
I had 2 of you's gunning at me, i was just protecting my corner and abit more.
Forgot to add if you like tea or coffee take a flask
Steve.
Steve.
1st i thought it was the sugar, but it ended up being the milk, well in date, and seemed ok, but once in the tea, gave it a horrid taste.
But i'm a cold drink fan, so didn't bother me to much.
B9kos and Jay. cheers.
good to see people like this about, top work fella
the welding on the lambda boss dan done compared to the other one, lol the original boss on it looks like a monkey has welded it on. where as dans looks flawless
good work fella
good work fella
Versus_Creations
24
Aug 5, 2015 09:32 PM
