pug 106 diesel - internet diagnosis!
Old Dec 29, 2007 | 08:56 PM
AlexF's Avatar
AlexF
Default pug 106 diesel - internet diagnosis!
Right,
Its a 1994 106 1.5 non-turbo diesel.
Has problems starting (cranks quickly and eventually fires), much worse when cold.
So far has had 4 glow plugs and the relay/timer/ecu.
Other information includes the Rad has recently (6months ago) was replaced and now the heater matrix is leaking.
What do you think it is??!!
Alex
Old Dec 29, 2007 | 08:57 PM
gkandr4ch's Avatar
gkandr4ch
A hole in the heater matrix.
Old Dec 29, 2007 | 09:00 PM
Lee_R21Turbo's Avatar
Lee_R21Turbo
I presume you've actually checked you are getting a voltage at the glowplugs??
Other than that you've got to be thinking a lack of compression somewhere headgasket, rings or perhaps injector fault??
Old Dec 29, 2007 | 09:02 PM
AlexF's Avatar
AlexF
Yes they get voltage - but not tested current draw or seen them glow.
If it was a inj fault then I would have though the problem wont affect all starts not just cold, and also affect the running (it runs fine when going).
Alex
Old Dec 29, 2007 | 09:07 PM
MK5RST's Avatar
MK5RST
Low compression.
Alvyn's Avatar
Alvyn
low compression more than likely got a cracked head!
Old Dec 29, 2007 | 09:09 PM
MK5RST's Avatar
MK5RST
Thats last years news
Old Dec 29, 2007 | 09:15 PM
AlexF's Avatar
AlexF
Are cracked heads common on the 1.5 lump?
Alex
Old Dec 30, 2007 | 06:22 AM
Put a 12v supply to the plugs prior to starting to see if it helps first, if it does you know you have a bad connection somewhere.
Have you drained the water off from the fuel filter head ?, just up the fuel pressure a bit, and use a CAV filter.
Stick a can of MILLERS diesel cleaner in there works wonders, did on my escort.
Old Dec 30, 2007 | 06:34 PM
AlexF's Avatar
AlexF
Old Dec 30, 2007 | 07:24 PM
cit-tech's Avatar
cit-tech
check tappets always exhaust that go tight no compression
Old Dec 30, 2007 | 07:26 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
Default Re: pug 106 diesel - internet diagnosis!
Originally Posted by AlexF
Right,
Alex
Leak down test done?
Old Dec 30, 2007 | 07:28 PM
markk's Avatar
markk
why did it have a rad ?
my guess loss of compression, eventually over pressured teh rad hence the leak, now its done the matrix, always looking for the weakest link !
Old Dec 31, 2007 | 09:07 AM
AlexF's Avatar
AlexF
almost...
Inlets are tight, infact one is permantly open
Exhuast are loose!!
So thats the poor starting and fast cranking explained.
Head/gasket looks fine - so the blown rad and leaky matrix could just be coincidence.
Alex
Old Dec 31, 2007 | 11:15 AM
richard youll's Avatar
richard youll
had loads of these now valves wear out as do the valve seats causing the tappets to go tight, re shim them in situ - like brand new afterwards!!
Old Dec 31, 2007 | 04:41 PM
timrud's Avatar
timrud
I'm running round in one at the moment, nice work horse and cheap as chips to run.
Are head gaskets common on them to go?
Old Dec 31, 2007 | 04:46 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
i would have said valve clearances.....done quite a few
benw456
Sep 16, 2015 05:27 PM
nikki.n.tom
Sep 15, 2015 08:20 PM
fordfiestamk3
Sep 11, 2015 12:52 PM
Bighandsuk
Sep 2, 2015 05:23 PM
