how can i translate a pdf file?
Old Dec 29, 2007 | 05:53 PM
lardypants's Avatar
lardypants
Default how can i translate a pdf file?
ive received some files for the equipment i use but there in german, opens up as a pdf file anything i can do?
Old Dec 29, 2007 | 05:55 PM
lardypants's Avatar
lardypants
Default does it get any better
oops wrong post lol
Old Dec 29, 2007 | 05:57 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
far as i know a PDF is like a scan of a piece of paper, it cant be changed.
Old Dec 29, 2007 | 06:03 PM
gkandr4ch's Avatar
gkandr4ch
Doesn't a PDF file use Adobe?
Old Dec 29, 2007 | 06:11 PM
Maxiboy's Avatar
Maxiboy
can,t you copy and paste sections into a translator like babelfish or do you need the whole document doing.
Old Dec 29, 2007 | 06:17 PM
saphycozzie-adz's Avatar
saphycozzie-adz
open it up with adobe acorat reader and then learn German
free down load from adobe.
Old Dec 29, 2007 | 06:20 PM
Adrian's Avatar
Adrian
Acrobat Reader 8
You can save files as text.
File > Save as text
Old Dec 29, 2007 | 06:49 PM
davidnormanuk's Avatar
davidnormanuk
PDF's can now be edited by a piece of software called pitstop. Works very well when files have been sent over and they decide they need changes doing to it. There may be a language converter on their website.
Dave
Old Dec 29, 2007 | 06:52 PM
StephenC's Avatar
StephenC
..BS Motorsport..
maybe print it, then scan it using OCR (if you've got a scanner) and put that into a translator.
Old Dec 29, 2007 | 06:54 PM
davidnormanuk
You would need to read it very carefully after using OCR software as sometimes it can misread text.
Old Dec 29, 2007 | 06:59 PM
lardypants's Avatar
lardypants
hmmn yes might be able to copy paste sections in as there all quite small
Old Dec 29, 2007 | 07:13 PM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
use an online convertor... simple as
http://www.freepdfconvert.com/convert_pdf_to_source.asp
Old Dec 29, 2007 | 07:33 PM
lardypants's Avatar
lardypants
mate that online convertor doesnt convert language?
Old Dec 29, 2007 | 07:36 PM
Turbocabbie
Top Cab !!
convert the pdf to a text document then throw it into bablefish, or just copy and paste the information into it if that's possible and translate it
http://babelfish.yahoo.com/
sorry i first throught you meant file type translation, not language... my mistake
Nov 1, 2015 06:53 PM
COSWORLD
Aug 14, 2015 07:40 AM
Petrucci
43
Jul 24, 2004 04:31 AM
Lee Reynolds
Jul 23, 2004 12:44 AM
