.86 to .64 A/R = :-)
Old Dec 29, 2007 | 12:14 AM
leecavturbo's Avatar
leecavturbo
Default .86 to .64 A/R = :-)
following from this thread https://passionford.com/forum/viewtopic.php?t=307992
just been out in the car after swapping
from a .86 to .64 hotside housing
and what a transformation
full boost well before 4k ,
feels so much better,
Old Dec 29, 2007 | 12:16 AM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
Just need to check the fueling low down now
Old Dec 29, 2007 | 12:17 AM
leecavturbo
i run compensation maps so should be ok but
will get it mapped as a safety
Old Dec 29, 2007 | 12:30 AM
marco polo's Avatar
marco polo
i think mine has .63 but not external tho
Old Jan 12, 2008 | 07:47 PM
leecavturbo
Definately does what it says on the tin.
Old Jan 12, 2008 | 07:58 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
0.63 A/R T3 housing is alot different to a 0.64 A/R T28 housing, which is what Lee has. It's all relevant to the size of turbo in any case, and contrary to alot of peoples opinions, regarding turbine housings bigger isn't always better.
Also, I would definately NOT rely on compensation maps, it's a very bad habit and only takes for your lambda sensor to have a 'moment' and you're looking at a meltdown. Remember that you now have 1.4 bar of boost somewhere in the map where it didn't have 1.4 bar before, so that part of the map may have not even been looked at.
Old Jan 12, 2008 | 08:57 PM
Rick's Avatar
Rick
C - it's a ratio, i know this, which means the physical size could be huge;y different. Is there a large physical difference between the two?
Rick.
Old Jan 12, 2008 | 09:03 PM
mitchrst's Avatar
mitchrst
1981
Wheres the cheapest place to get one of these turbos ?
Old Jan 12, 2008 | 09:24 PM
Christian and Beccy
#1 in Spelling Club
One of what turbo's? Lee's is one of many GT Series turbo's out there. There are 10's of different variations.
Old Jan 12, 2008 | 09:36 PM
Rick's Avatar
Rick
Old Jan 12, 2008 | 09:49 PM
Christian and Beccy
#1 in Spelling Club
Originally Posted by Rick
WTF?
Old Jan 12, 2008 | 09:50 PM
mitchrst's Avatar
mitchrst
1981
I mean the GT2540R Christian or a GT28RS
Old Jan 12, 2008 | 09:51 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
WTF?
He's asking you something, hence the C.
Old Jan 12, 2008 | 09:53 PM
Christian and Beccy
#1 in Spelling Club
Rick.
Fuck knows. Happy now?!!??!
Old Jan 12, 2008 | 09:54 PM
Rick's Avatar
Rick
no. answer my question!
Old Jan 12, 2008 | 09:55 PM
Christian and Beccy
#1 in Spelling Club
Those 2 turbo's are quite different IMO.
I'd expect up to 350bhp from the GT28RS and over 400bhp from the GT2540R personally. As for where is cheapest to get them, that would be importing from the US probably (if you're flukey enough to avoid customs/VAT charges), but should price be your one concern?
MK5RST's Avatar
MK5RST
WTF?
Ahhhh i thought the C stood for Cunt [/b]
Old Jan 12, 2008 | 09:56 PM
Christian and Beccy
#1 in Spelling Club
Is there a big physical difference? Not that is immediately obvious to the eye, but IMO, the 0.64 A/R T28 housing is roughly comparable to the 0.48 A/R T3 housing.
Better??
Old Jan 12, 2008 | 09:57 PM
Rick's Avatar
Rick
C
Old Jan 12, 2008 | 09:58 PM
Charlie Chalk
Unknown.
Rick.
This one?
Old Jan 12, 2008 | 09:59 PM
Christian and Beccy
#1 in Spelling Club
Is this the most complicated question/answer scenario ever??!!
Rick's Avatar
Rick
No. Shit answer i'm afraid. You haven't justified your opinion. I'd just give up if i were u
Old Jan 12, 2008 | 10:01 PM
Christian and Beccy
#1 in Spelling Club
Well, I have far more important things to do than make pointless physical comparisons between different turbine housings, I am usually more interested in fitting them to the car and letting the dyno do the talking.
Though, I think my answer was quite informative.
Rick - Have you been drinking??
Old Jan 12, 2008 | 10:08 PM
Rick's Avatar
Rick
Pointless? I beg to differ....
This wll give u a rough idea of flow capacity.
But - you're right, and i forgot that u had a dyno!! Have u done a dyno compare on the same engine and front end?
Old Jan 12, 2008 | 10:12 PM
Christian and Beccy
#1 in Spelling Club
We're very picky this evening, aren't we??!!
There is no way that from studying the physical size, you could judge the performance. I have both a 0.64 and a 0.86 A/R T28 housing and externally you couldn't tell the difference. I know how they both perform and how the 0.63 A/R T3 housing performs by comparison.
Old Jan 12, 2008 | 10:24 PM
Rick's Avatar
Rick
As they are internally bored differently
Why questioning is this:
Both housings are ment for the same front end - ie. a turbo that can flow x amount of air. Now u say that the 63 and 64 are really different. one is 25, one is t3. as far as i can tell, this is just bolt pattern, and has little to do with intake area? a ratio of 63 to 64 makes naff all difference if both housings have similar physical dimesnions. you say they are diff - i want to know why
Old Jan 13, 2008 | 05:25 PM
leecavturbo
Compensation map seems to be eeerrrrrrmmm fookin spot on.
just did another spark plug check and they look so perfect,
so much better than in the pic, these have a few thousand
miles on too
Old Jan 13, 2008 | 05:43 PM
Charlie Chalk
Unknown.
My T28 has a .86 , I hate how laggy it is!
where can I get a .64 from?
Old Jan 13, 2008 | 05:50 PM
leecavturbo
got my .64 for Ł100 delivered genuine garrett
brand new from atp turbo.
straight bolt on job.
Old Jan 13, 2008 | 06:04 PM
Charlie Chalk
Unknown.
Ah nice one
robbo9006
11
Sep 1, 2015 02:10 PM
IAN RS2k
Aug 18, 2015 07:51 PM
Sonic Boom
Sep 13, 2006 07:07 PM
Perkele
Ford Escort RS Cosworth
Apr 24, 2006 09:16 AM
scooby8272
Oct 15, 2004 08:58 PM
