Fuel tank foam?
Old Dec 28, 2007 | 06:31 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Default Fuel tank foam?
Where from, I need a quick fix to stop it surging on fast cornering. It surges at anything from half a tank of petrol or below
Is it just a case of stuffing the tank with foam, and can it be done in situ?
Thankenyou
Old Dec 28, 2007 | 06:34 PM
nilrem's Avatar
nilrem
STOP!... Carry on
i do believe you need to buy the tanks with the foam already in, its not like expanding faom that you use to insulate holes in brick work with...
Old Dec 28, 2007 | 06:42 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
........no man......shut up and tell him to go to b&q..........................the car will float soon.........
Old Dec 28, 2007 | 06:45 PM
focusv8's Avatar
focusv8
It's here, so it should be available in the U.K:
http://store.summitracing.com/egnsea...115+4294849078
Old Dec 28, 2007 | 06:46 PM
nilrem's Avatar
nilrem
STOP!... Carry on
http://www.wickes.co.uk/invt/156667
sorry rads...
but this is the kinda thing that you mean i assume?
http://www.sm-engineering.co.uk/alloy_fuel_tank.php
Old Dec 28, 2007 | 06:48 PM
focusv8's Avatar
focusv8
I am the only serious one?
http://www.demon-tweeks.co.uk/produc...code=ATLSF103Y
Old Dec 28, 2007 | 06:56 PM
nilrem's Avatar
nilrem
STOP!... Carry on
Originally Posted by focusv8
aint that for when you are making a fuel tank? also, if you put that in, it would just slosh about anyway, wouldnt it?? you would need to get the foam a little bigger than the largest area of the tank? i am being seriaous about it, i just havent heard of it where you can just throw it in your old tank...
Old Dec 28, 2007 | 06:58 PM
Charlie Chalk
Unknown.
So you cant just fill your old tank
Thanks
Old Dec 28, 2007 | 07:10 PM
focusv8's Avatar
focusv8
The foam has a limited life and has to be replaced even in filled cells, so it must be flexible enough to squeeze in through a small opening.
Old Dec 28, 2007 | 07:39 PM
markk's Avatar
markk
the foam does not stop fuel surge at all, if you are suffering surge then it needs to be sorted properly, all the foam does is abosrbs the fuel to prevent masses of fuel loss all at once in accidents if the tank splits
Old Dec 28, 2007 | 07:47 PM
OldDan's Avatar
OldDan
And how do you sort fuel surge? a proper regulator?
Old Dec 28, 2007 | 07:49 PM
glancy2081's Avatar
glancy2081
a fuel swirl pot is needed to stop fuel starvation
Old Dec 28, 2007 | 07:53 PM
markk's Avatar
markk
i tried the lot years ago, a pukka foam mil spec tank, differant pickup points, differant pumps and non sorted it, in fact the foam actually fooked two brand new fuel pumps up in no time, swirl pot resolved the lot
Old Dec 28, 2007 | 07:54 PM
glancy2081's Avatar
glancy2081
and so easy and cheap to make too
Old Dec 28, 2007 | 07:57 PM
markk's Avatar
markk
very very true
Old Dec 28, 2007 | 08:31 PM
Charlie Chalk
Unknown.
very very true
Damn, wanted a quick fix...
What kinda price am I looking at to get a swirl pot/new pump fitted?
minus aeroquip, jubilee clips will do for now
Old Dec 28, 2007 | 08:38 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Fuel tank foam isnt the solution, but it will be better than nothing.
I got a TON of it here if you wanted it.
Old Dec 28, 2007 | 08:43 PM
dovboy's Avatar
dovboy
foam didnt help the surge on mine but if you want to try it i pushed cubes down the filler neck...
http://www.merlinmotorsport.co.uk/FUEL-SYSTEMS-Tank-Foam/c26_27/p737/56-CUBES-TANK-FOAM-(CUBIC-FOOT)/product_info.html
if not i have a 4l proalloy swirl pot i had made for my cos that is not of any use to me now(brand new).
Old Dec 28, 2007 | 08:44 PM
dovboy's Avatar
dovboy
better link
http://www.merlinmotorsport.co.uk/FU..._27/index.html
Old Dec 28, 2007 | 08:47 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
Spot on! I read the post earlier an meant to say the same
Old Dec 28, 2007 | 08:52 PM
andrewg's Avatar
andrewg
try putting more than a fiver in it.
what car is it on??
Old Dec 28, 2007 | 08:54 PM
Charlie Chalk
Unknown.
what car is it on??
Erm... I had a FULL tank, and through the day it ran out funny enough.... When it gets to half a tank it surges!
Nissan GTiR
Old Dec 28, 2007 | 09:05 PM
glancy2081's Avatar
glancy2081
there is a fuel swirl pot on ebay the now cheap get a bid in rads
Old Dec 28, 2007 | 09:18 PM
Charlie Chalk
Unknown.
dont suppose you can find the link , im watching a film lol
Old Dec 28, 2007 | 09:22 PM
glancy2081's Avatar
glancy2081
a just typed in fuel swirl pot and there was two of them.ps dont know how to put link up
Old Dec 28, 2007 | 09:23 PM
Charlie Chalk
Unknown.
Oh ok
Old Dec 28, 2007 | 09:25 PM
andrewg's Avatar
andrewg
what car is it on??
Nissan GTiR
most tanks have an internal collector maybe this has came away
should never surge with half a tank
Old Dec 28, 2007 | 09:38 PM
Charlie Chalk
Unknown.
what car is it on??
Nissan GTiR
It was a high speed corner I was doing at a track/activity day,around 80mph.. so maybe it wont be as bad on track?
Old Dec 28, 2007 | 09:39 PM
Martin-Hadland
what car is it on??
Nissan GTiR
Just use a separate swirl pot mounted under the car, I can do this if needed
Old Dec 28, 2007 | 09:43 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
what car is it on??
Nissan GTiR
it is quite possible i reckon
on track at ford fair last year (silverstone) i was in a group n fiesta st and done a few sessions, when it got to half a tank it surged like fook on the corner that leads onto the start/finish straight
but i broke the car later anyway so it didnt matter
Old Dec 29, 2007 | 01:40 AM
Charlie Chalk
Unknown.
Hoping to win a pot off fleabay in the morning
Old Dec 29, 2007 | 02:32 AM
Ollie.'s Avatar
Ollie.
GTiR's seem to be common for this. My mates one did this on left hand bends under 1/3 of a tank....
Old Dec 29, 2007 | 05:33 AM
xr-stu's Avatar
xr-stu
you will need a low pressure high flow fuel pump like one of facets offerings. obviously check its capable of flowing enough fuel for the engine at full chat.
need to replumb the system slightly to mate, chuck in new wiring (relay/inertia switch etc) and you'll be away.
Old Dec 29, 2007 | 08:11 AM
markk's Avatar
markk
the low lift pump doesnt need to be and wont be enough to fuel a large turbocharged engine as all its doing is keeping the pot topped up
Old Dec 29, 2007 | 08:15 AM
RichardPON's Avatar
RichardPON
Agreed. Heard of this before too.......
Old Dec 29, 2007 | 12:30 PM
Charlie Chalk
Unknown.
Missed it by a fucking quid!
Old Dec 29, 2007 | 12:51 PM
glancy2081's Avatar
glancy2081
cheap skate
Old Dec 29, 2007 | 12:55 PM
Charlie Chalk
Unknown.
It wasnt me bidding I dont have an account
Old Dec 29, 2007 | 08:33 PM
xr-stu's Avatar
xr-stu
of course it needs to be able to flow as much as the high pressure pump. otherwise when the engines consuming more fuel that the poxy lift pump can supply, the pot will run dry and rad will end up with 3 and a 1/2 pistons instead of 4.
think before you type.
Old Dec 29, 2007 | 08:34 PM
xr-stu's Avatar
xr-stu
to be fair rad the other bidder could have bid £100 more than you, but the bids only go up by a quid at a time!
