Are all sapphire clocks the same?
don't think so Rick.
iirc the 4x4 saff clocks don't have numbers on the fuel gauge...where 2wd has!
might be wrong though...don't think there is a lot of difference...
speedos on cossie are 170 normal are 150
revcounters are different too (most are interchangeable mechanically tho)
i THINK they look different (i know mk1 and mk2 are different on sierras at least)
if however you mean the clock (time) thing then yes theyre the same as long as its the type with the AWS module not the big coin-holder thing
Jim i meant within the cosworth variety
http://cgi.ebay.co.uk/ws/eBayISAPI.d...tem=2494136767
Just need to know if they are compatible with the 4wd's
Mr S1
20
Sep 27, 2015 04:06 PM
