parts for RS1800
Old Dec 25, 2007 | 03:14 PM
JezSierra's Avatar
JezSierra
happy with that
Default parts for RS1800
my car has had a 2.0zetec lump put in it,was wondering if the heads on 2.0 zetecs and the head off the RS1800 zetecs are the same
also im after a stainless exhaust system,and a 4branch,where would be the best places for these
also best airfilter
also will st170 calpers and discs fit under 16' wheels
cheers
Old Dec 31, 2007 | 02:15 PM
JezSierra's Avatar
JezSierra
happy with that
oh and can anyone recomend a good clutch?
Old Dec 31, 2007 | 03:58 PM
RS_Rob's Avatar
RS_Rob
i've heard the rs1800 head and 2.0 head are the same
not sure really, if you have a 2.0 then use the 2.0 item
as for exhaust go for an off the shelf exhaust such as mongoose or scorpion as they have proven gains and spent loads researching to get the best power from the exhaust, unlike a powerflow system which is just made to fit and wether you gain power or loose it is a gamble
for a 4 branch this aint soo simple, all require minor modding
the choices are
rs2000 4 branch
st170 4-2-1 as they come standard with one
or an ebay jobbie
got a feeling ashley do a 4 branch aswell so depends how big your pockets are
best airfilter
personally k&n panel filter in the original filter housing as they induction kits suck alot of warm engine bay air, unless you sort a good cold air feed
and finally
300mm discs such as st170 brakes will need 16" wheels and bigger
hope this helps
Old Dec 31, 2007 | 04:37 PM
JezSierra's Avatar
JezSierra
happy with that
brillient,cheers for the info,think ill go for the st170 4branch,are they hard to get hold of?
cheers again
Old Jan 1, 2008 | 09:38 PM
RS_Rob's Avatar
RS_Rob
well always hard whenever you want them lol
think their about £150 - £170 from fords new
gambo08
Feb 4, 2016 10:49 PM
Oct 1, 2015 02:00 PM
fordrallycar
Sep 30, 2015 07:57 PM
Fordmad!
Sep 29, 2015 07:03 PM
