parts for RS1800
happy with that
my car has had a 2.0zetec lump put in it,was wondering if the heads on 2.0 zetecs and the head off the RS1800 zetecs are the same
also im after a stainless exhaust system,and a 4branch,where would be the best places for these
also best airfilter
also will st170 calpers and discs fit under 16' wheels
cheers
also best airfilter
cheers
i've heard the rs1800 head and 2.0 head are the same
not sure really, if you have a 2.0 then use the 2.0 item
as for exhaust go for an off the shelf exhaust such as mongoose or scorpion as they have proven gains and spent loads researching to get the best power from the exhaust, unlike a powerflow system which is just made to fit and wether you gain power or loose it is a gamble
for a 4 branch this aint soo simple, all require minor modding
the choices are
rs2000 4 branch
st170 4-2-1 as they come standard with one
or an ebay jobbie
got a feeling ashley do a 4 branch aswell so depends how big your pockets are
best airfilter
personally k&n panel filter in the original filter housing as they induction kits suck alot of warm engine bay air, unless you sort a good cold air feed
and finally
300mm discs such as st170 brakes will need 16" wheels and bigger
hope this helps
the choices are
rs2000 4 branch
or an ebay jobbie
best airfilter
and finally
hope this helps
07-10-2015 12:56 PM
