When does too much become too much?
Old Oct 12, 2004 | 11:22 AM
RWD_cossie_wil's Avatar
RWD_cossie_wil
Default When does too much become too much?
I'm at a point now where I need to make major decisions about the final spec of my cossie engine build, but just wondering if going mega spec is worth the huge increase in cost? how long does a 600BHP+ engine last, and is it a mega step over 550 ish?
Old Oct 12, 2004 | 11:26 AM
wimwerf's Avatar
wimwerf
how long a 600bhp engine last. depends on how many you drive the car in a year. it also depends at what kind of boost you are driving. if you drive a 600bhp spec engine with 14psi it will last a while.
whats the spec you have now?
Old Oct 12, 2004 | 11:31 AM
Porkie's Avatar
Porkie
All depends on components used. For example, Thrashing the nuts of a T4 to make over 500bhp is ALOT harder on the entire engine than making it easily with a GT35. Everthings working at a much lower temp and is therefore having an easier time
Old Oct 12, 2004 | 11:33 AM
RWD_cossie_wil
got a GT35 just wondering if its worth going farndon rods/crank
Old Oct 12, 2004 | 11:38 AM
wimwerf's Avatar
wimwerf
better cranks and rods then the cossie stuff is always very good and expensive
Old Oct 12, 2004 | 11:43 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
First you need to settle on a power figure you want and rev ceiling, then you can decide if you need the extra exspense of the rods and crank .
Old Oct 12, 2004 | 11:46 AM
RWD_cossie_wil
lol you will be wearing your keyboard out on this topic mike
Old Oct 12, 2004 | 11:51 AM
Mike Rainbird
Caraholic
If you want to make full use of your GT35, then you'll be wanting it to rev to 8500, which will mean different valve-train, rods and crank .
Alternatively you could go for a more budget orientated engine and be happy with 600 bhp...
Good head , solid lifters (as the GT35 will be wanting to live at 8k ) and standard (but perfect condition) rods and crank and genuine Cosworth LOW COMP pistons.
Old Oct 12, 2004 | 12:05 PM
CozzyBrom's Avatar
CozzyBrom
mike you forgot your plug for your plenum in there
will fardon rods are a must if you wana get in the high 8000 range
also you can have a big spec engine run it low boost and still see 500 plus
wheres this spliter you sposed to be getting
Old Oct 12, 2004 | 12:06 PM
Mike Rainbird
Caraholic
Brom,
He already knows about that .
Old Oct 12, 2004 | 12:12 PM
ImaRacing 700's Avatar
ImaRacing 700
Well...i could have gone 600 plus BUT mine is a road car so deceided on a high comp big torque effort....Drivibilty around normal everyday roads is the key..been lo comp...drives shit off boost...high comp...its a beauty....and mine will whoop boy Mikes mega cost build
Old Oct 12, 2004 | 01:14 PM
Mike Rainbird
Caraholic
Phil,
And just where do you intend on proving that claim? - I think my car will slaughter yours in the dash from one side of your living room to the other .
Old Oct 12, 2004 | 01:22 PM
PGT's Avatar
PGT
bttt
this ones interesting!
