BIG brakes
Old Jan 26, 2004 | 05:06 PM
Default BIG brakes
Just wondering if any one knew of a good brake conversion for a 1.6 xr2i. The standard front discs as we all know are poo and i would like to change them for another set of ford callipers and discs ie mondeo or even escort cossie but i do not have a clue if any of these would fit any help would be much appreciated.
Thanks darren
Old Jan 26, 2004 | 05:12 PM
kjc300's Avatar
kjc300
ST170!!!! 300mm discs - drill out the hub carrier bolt holes to 12mm (from 10) and they go straight on apparently!!
Old Jan 26, 2004 | 08:12 PM
I may try and find more out about that mate. What callipers would i use though.
Old Jan 27, 2004 | 05:31 PM
I have just been told that saph cozzie 4x4 disc and 2wd callipers will fit, is this true or not. Help me please my brakes suck...........
Old Jan 27, 2004 | 10:54 PM
kjc300's Avatar
kjc300
ST170 calipers!!!!!
Old Jan 28, 2004 | 11:21 AM
S1MAN's Avatar
S1MAN
If you want to go down the Cossie route I suspect that it's the 4*4 calipers and the 2wd disc's that you need.
That's what I use on my S1 and they're spot on.
Beware of the 2wd calipers as they're 4 pots and are too large to fit easily , certainly within the 15" S1 wheels.
Colin.
Old Jan 28, 2004 | 03:01 PM
xrsi's Avatar
xrsi
no its 4wd disks and calipers for a fiesta!
the calipers need spacing out 5mm tho and 30mm bolts need to be used to hold them on!
Old Mar 3, 2004 | 01:05 PM
Default big brakes
www.pumaspeed.co.uk sell 280mm cossie brakes spec kit.Does this spec kit include all accessories?What about rear brake disc conversion,is it good?
Ps.sorry my english is not so good
my car is Fiesta XR2i,autoslalom racecar
Old Mar 6, 2004 | 04:51 PM
ive got a problem ive got a sierra rear disc conversion on my s2 rs turbo and i have cross threaded 2 of the wheel bolts. do you know what hub they use with this conversion so i can buy a new one thanx
Old Mar 6, 2004 | 07:00 PM
Micky's Avatar
Micky
It uses the standard R.S. Turbo hub!!!!!Just has the drum brake removed.Regards Micky
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
