Group A head gasket for S2 - pros and cons?
Old Oct 11, 2004 | 07:12 PM
Wazzzer's Avatar
Wazzzer
Default Group A head gasket for S2 - pros and cons?
I'm getting a full gasket set for my engine when I rebuild it, and I was looking at the set which includes the Group A headgasket over the standard one...
Anyone got any experience with these and are they worth the extra?
Any help appreciated
Old Oct 11, 2004 | 07:34 PM
ballin's Avatar
ballin
ford gasket mate
Old Oct 11, 2004 | 08:00 PM
James Porter's Avatar
James Porter
Put a GRP A on my rs and it blew a hole in my head instead!
James.
Old Oct 11, 2004 | 08:02 PM
Shings's Avatar
Shings
Ford gasket- direct from Ford, always- Mine uses a ford gasket.
For an example- it was started on sat afternoon and as soon as she was warmed up we ran a bar through it- today she's had up to 28psi.
Old Oct 11, 2004 | 08:04 PM
Wazzzer's Avatar
Wazzzer
Jeez
Might have to go proper Ford then
Old Oct 11, 2004 | 08:06 PM
Lee Reynolds's Avatar
Lee Reynolds
WOW i didnt know that! Now i do i know what ill use over winter
Old Oct 11, 2004 | 08:40 PM
Shings's Avatar
Shings
To be honest lads- everything I get is proper ford.
leads/gaskets/bolts/studs
1million + spent designing a part Vs some rip off shite
Old Oct 11, 2004 | 08:44 PM
James_RST's Avatar
James_RST
ive just replaced the one in my car with a ford item. see how this one holds up
Old Oct 11, 2004 | 08:52 PM
AndyRST's Avatar
AndyRST
If it was me it would be a std Ford one everytime.
Old Oct 11, 2004 | 08:54 PM
Shings's Avatar
Shings
think they're 45 quid btw everyone- please dont let it put you off. they're the man for the job
Old Oct 11, 2004 | 08:56 PM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
No such thing as Group A for an RST PMSL
Old Oct 11, 2004 | 09:03 PM
Wazzzer's Avatar
Wazzzer
Woodford Garage Motorsport do the whole group A engine gasket kit including bolts for just over a ton, so the Ford one should be about the same, wil give them a bell to find out 2moro
Old Oct 11, 2004 | 09:32 PM
Moose 130's Avatar
Moose 130
Genuine ford ERST is best.
I used a Grp A on a 1600 cvh and the gasket bore is too big, its a Felpro one from a 1.9 usa engine.
It is the corect size for a 2.0zvh though. Don't know at what boost it becomes a liability though, I'm going to run 10psi and keep it safe.
Old Oct 11, 2004 | 09:36 PM
EIL132's Avatar
EIL132
Ford, aftermarket are shite. Lost a head due to Felpro gasket failure
Old Oct 11, 2004 | 09:38 PM
Moose 130's Avatar
Moose 130
Only Ford make a gasket AFAIK specific to an ERST.
Old Oct 11, 2004 | 10:10 PM
Lee Reynolds
I do always try and stick ford.I went todat and got some tubing for amal to actuator, temp sender, rad fan sender and the turbo/starter heatsheild. There aint much in the prices compared to patten imo
Old Oct 11, 2004 | 11:39 PM
Daviet's Avatar
Daviet
was same got a felpro gasket before thought it was a little big bought a ford one and that was fine but probaly alot less power than yours.
someone on fea bay just took felpro one of my hands
lee they starter heat shields did ford have them in stock or did u have to order it.gonna have to go tomorow and see
Old Oct 12, 2004 | 12:01 AM
Hardeep_Singh's Avatar
Hardeep_Singh
yep go oe mate when i did the headgasket on mine i used all genuwine ford parts as insisted by karl, havent had any probs
Old Oct 12, 2004 | 05:47 AM
JesseT's Avatar
JesseT
When has ERST been used in group A level motorsport
Indyrs
Dec 4, 2022 12:39 PM
Fiddy
21
Sep 29, 2015 06:10 PM
pie-face
Sep 15, 2015 10:43 AM
