Group A head gasket for S2 - pros and cons?
I'm getting a full gasket set for my engine when I rebuild it, and I was looking at the set which includes the Group A headgasket over the standard one...
Anyone got any experience with these and are they worth the extra?
Any help appreciated
Ford gasket- direct from Ford, always- Mine uses a ford gasket.
For an example- it was started on sat afternoon and as soon as she was warmed up we ran a bar through it- today she's had up to 28psi.
Woodford Garage Motorsport do the whole group A engine gasket kit including bolts for just over a ton, so the Ford one should be about the same, wil give them a bell to find out 2moro
Genuine ford ERST is best.
I used a Grp A on a 1600 cvh and the gasket bore is too big, its a Felpro one from a 1.9 usa engine.
It is the corect size for a 2.0zvh though. Don't know at what boost it becomes a liability though, I'm going to run 10psi and keep it safe.
I do always try and stick ford.I went todat and got some tubing for amal to actuator, temp sender, rad fan sender and the turbo/starter heatsheild. There aint much in the prices compared to patten imo
was same got a felpro gasket before thought it was a little big bought a ford one and that was fine but probaly alot less power than yours.
someone on fea bay just took felpro one of my hands
lee they starter heat shields did ford have them in stock or did u have to order it.gonna have to go tomorow and see
Indyrs
04-12-2022 12:39 PM
