removel ov oil pump and then refit 2wd cossie
Old Jan 26, 2004 | 12:33 PM
yogi's Avatar
yogi
Default removel ov oil pump and then refit 2wd cossie
as above is it a case of just droppin the sump and undoing the oil pump or is there crank or pulleys in the way any help will be great cheers
Old Jan 26, 2004 | 05:25 PM
Alvyn's Avatar
Alvyn
Default Re: removel ov oil pump and then refit 2wd cossie
[quote="yogi"]as above is it a case of just droppin the sump and undoing the oil pump
just like the above m8 is!
Old Jan 26, 2004 | 10:05 PM
Toe Knee's Avatar
Toe Knee
Probably already know this but you'll have to take the whole engine out as u cant drop the sump off on a 2wd!! Unless u drop the front cross member which can be an arse!
Old Jan 27, 2004 | 05:22 PM
also when you put the pump back on make sure you fill it with oil so you can get pressure if you still struggle to get pressure up then you can pump oil down the central vein where the oil filter screws in. this should definatly work if you have any problems like i did.
Old Jan 27, 2004 | 08:33 PM
yogi's Avatar
yogi
cheers lads for the info engine is already out of the car so shouldnt be a big problem cheers
Old Jan 27, 2004 | 09:01 PM
Mark_w's Avatar
Mark_w
remember its a special long star bit aswell to get it off,cant remember the size
mark
big_Rad
Sep 15, 2017 09:36 AM
Cosnada
Sep 2, 2015 01:10 AM
FlashRS
13
Aug 31, 2015 06:02 PM
Adam-M
Aug 26, 2015 05:53 PM
Dubs44
Aug 21, 2015 02:42 PM
